!!! Show off your 87-91 Trucks !!!
Old 04-16-2015, 04:50 PM
88XLTLariat's Avatar
88XLTLariat
88XLTLariat is online now
Originally Posted by jthorngate3
Very nice truck. Love the Coopers! What gearing are you running on the 302? I feel like my 302 is a dog. Not sure it would manage that kind of load.
Pyleketerson, that is a sharp looking truck. Do you have any rubbing issues with the 35's with just a 3" body lift?
I'm running 3.55 gears with limited slip on 35" Coopers. Pulls great, MPG not so great. LOL
  #212
Old 04-16-2015, 07:33 PM
Jeff64F100CrewCab's Avatar
Jeff64F100CrewCab
Jeff64F100CrewCab is offline
My just-purchased '87! Only 118k miles on it too.
  #213
Old 04-16-2015, 09:35 PM
jthorngate3's Avatar
jthorngate3
jthorngate3 is offline
How much lift do you have to fit the 35's? I have 3.55 as well I am pretty sure, though not limited slip and an auto. That probably doesn't help me much.
  #214
Old 04-16-2015, 10:09 PM
88XLTLariat
4" suspension lift and 2" body lift for the 35's. I could probably go with larger tires but my turning radius already sucks and my power steering pump probably couldn't handle the extrea strain. If you do a lot of towing, a 4.10 gear swap might help.
  #215
Old 04-16-2015, 10:18 PM
jthorngate3
I don't do any towing really. My truck doesn't really seem like it wants to move its own weight around, let alone more weight. The truck currently has a 3" body lift on it from the PO. Not my preference and I am debating with myself whether to leave it or take it off.
  #216
Old 04-16-2015, 10:40 PM
88XLTLariat
As far as the lift, I guess it depends on what you use the truck for. It's nice to have a lift for heavy loads such as gravel, wood, etc. & off roading. But if it's just your daily driver, you might benefit from lowering truck. How many miles on your engine? Does it just need some upgrade mods for more power or is it just tired?
  #217
Old 04-17-2015, 12:22 AM
FarmerJon's Avatar
FarmerJon
FarmerJon is offline
Our 87 F250 4x4 XLT Lariat 460 4sp 4.11 LS .she might be a little old but works as hard as ever just not as pretty.
  #218
Old 04-17-2015, 05:28 PM
jthorngate3
No truck in my life will ever go lower, only higher. That being said, I have just never liked the body lifts. I would eliminate it and replace with a suspension lift. I still want to do a suspension lift, just don't know if it will supplement the body lift or eliminate it. The engine is just shy of 100k, but I think it spent a decent amount of time idling. I haven't had a chance to investigate the state of the motor in depth, but I do know it has low oil pressure. Whether it's just clogged up, worn out oil pump/screen, or worn out engine is yet to be determined.
  #219
Old 04-25-2015, 05:44 PM
jthorngate3
Couple pictures I took today. Mostly close ups, as I don't typically do those.
Old tint removed on driver's side
Old tint still there on passenger's side
And what sounds to be a somewhat uncommon skid plate for the T-case
  #220
Old 04-26-2015, 04:27 PM
jthorngate3
Few more pictures from today. Drove the truck around a bit in the woods after our CT chapter gtg.
  #221
Old 05-10-2015, 07:55 PM
TexanTillIDie's Avatar
TexanTillIDie
TexanTillIDie is offline
[QUOTE=goodB0Y;10131163]my 91 F250 with 92-96 front clip and one ton running gear
goodBOY: How did you change the front end? New owner here.
  #222
Old 05-10-2015, 08:28 PM
TexanTillIDie
My 1990 F-150 Lariat and my first truck
  #223
Old 05-10-2015, 08:51 PM
DarrinGT's Avatar
DarrinGT
DarrinGT is offline
  #224
Old 05-10-2015, 11:48 PM
ckdc's Avatar
ckdc
ckdc is offline
1990 460 Needs some love but still looking good- just installed Banks Headers and exhaust.
  #225
Old 05-11-2015, 01:12 AM
Krisverde's Avatar
Krisverde
Krisverde is offline
Quick Reply: !!! Show off your 87-91 Trucks !!!
