horsepower rating of 351W ?
Old 12-15-2014, 05:58 PM
nikmish's Avatar
nikmish
nikmish is offline
if you from San Francisco Bay area, keep in mind that there are rules (California) for swapping engine in your truck. It has to be from a newer model and with all smog accessories.
Old 12-15-2014, 09:51 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Have you pulled the codes and asked the computer how it feels? While bad gas mileage in a pickup truck is a given, your engine is computer-controlled and there could be a problem it knows about - even without a Check-Engine light.
Old 12-16-2014, 01:52 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
Originally Posted by HenryBaker
Oh thanks. ok well thats true it doesn't smoke or leak. It's just tired and slow. What could I do to improve its performance? without replacing. I have replaced spark plugs/wires. Fuel filter, throttle body cleaned. replaced some exhaust valve.
there is one noise that concerns me. its a chug-a-lugging helicoptor, almost metalic sound. i epecially hear it while going uphill, when it feels like it struggles. it has headers and flowmaster exhaust and this sound is easily heard over the exhaust. anyone know what it could be? bores large from being an old engine? some sort of seal?
thanks
A engine that doesn't use any oil and doesn't knock or tick is not "tired". I am trying to read between the lines here, it sounds like you have a perfectly sound engine, but are disappointed in it's power output. If that is the case, then putting another engine in it that is exactly the same is not going to get you anything.
If you think you have a problem, you need to troubleshoot it. I haven't heard any real problems from you though, you just don't like the power output.
Is this a 4x4? Look on the tag on the doorjamb and tell us what axle code you have, and what tranny code you have.
Johno.h
05-10-2016 07:55 AM
mad scientist:p
03-23-2006 02:24 PM
frankh
07-09-2000 03:39 PM
picklebill
12-17-1999 08:22 AM
doug
08-15-1999 07:25 PM
Quick Reply: horsepower rating of 351W ?
