Slight 300 Makeover
Slight 300 Makeover
I picked up an 83 Bronco a while back and when I got the motor started (carb rebuild and tune-up) it was spewing oil out of the rear main seal and leaking from the valve cover, lifter cover, oil pan, and any other place oil is present. I ended up pulling the motor to replace the gaskets and clean up 27 years worth of caked and baked oil.
Here is what I started with:
Bronco
300
Removed smog pump and other emission equipment
Degreased in the engine bay (not good enough)
Out with it
Lots of elbow grease
Stubborn spots
More elbow grease
Stripped
New oil pump and pick-up
Cast iron paint
Wrinkle finish on valve cover and lifter cover
Flat black coated efi exhaust manifolds
Distributor, wires, coil, fuel pump, etc.
Intake pretty much ready to go back in
Fred
Bronco
300
Out with it
Stubborn spots
More elbow grease
Stripped
Cast iron paint
Fred
The carb didn't need anything really. This year had a non-feedback carb so removing the smog equipment didn't affect it. For the spacer, I ran down to a local junk yard and snagged a non egr spacer from what looked to be a 200 or 260. It had a dual bolt pattern so it fit nicely. I made shorter studs. I used a brass plug for the egr port on the exhaust manifold. Will get pics of everything tomorrow.
Yes, trimmed the alternator bracket as well as the AC bracket. No meed for either since it will be a dedicated trail rig.
Good job--It looks great. The only thing that hurts is seeing you reinstall the oem intake and carb, but, to each their own. While I had it out I think I would swap the int/exh. bolts, and the fuel pump bolts to studs.
Use a drill to prime the oil pump and pump oil all the way to the head before your start up.
Nice. k
Nice. k
