1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Need Wiring Diagram For PCM
Old 03-17-2011, 08:02 AM
fred.mason's Avatar
fred.mason
fred.mason is offline
Hey to all,
I have a 2005 F250 with a 5.4L 3V engine. I have been getting a CPS fault code. I have replaced both sensors and checked the alternator. I found a test procedure which had me disconnect the wires from the PCM and the sensors and check for voltage with the key on. It states that I should have less than 1volt on the + of the sensor harness at this point. I actually have almost 4 volts which indicates a short in the wiring harness. I need to trace the wiring through the harness and would like to know if any other devices share the suspect wire. I have been trying to find a copy of the wiring diagram but not having any luck. Would anyone happen to have a copy to share or know where I may find one?
Thanks
phatmarcus
07-27-2021 10:52 PM
bcarterjr
New Member Introductions
07-02-2015 02:23 PM
Iceman5192
1997 - 2003 F150
08-15-2013 09:54 PM
rcraig
02-19-2007 11:33 PM
Derwydi
01-05-2001 08:39 AM
Quick Reply: Need Wiring Diagram For PCM
