01 F150. can i use e85?
Old 03-13-2011, 06:19 PM
Ravenwood Ranch's Avatar
Ravenwood Ranch
Ravenwood Ranch is offline
I don't.have. the book but I.want to use e85 has a 4.6 and is a 4x4
Old 03-13-2011, 08:34 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
No, you cannot.
Old 03-13-2011, 10:20 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
computer is not calibrated for that, and you will probably screw up the O1 sensors. Ethanol gas is 10% and that works o.k. I think you can run about 30% without problems, not 85%
Old 03-13-2011, 11:59 PM
Ravenwood Ranch
So put like 5 gallons e85 with the rest regular
Old 03-14-2011, 09:03 PM
steve(ill)'s Avatar
steve(ill)
if you insist, but your milage will drop and probabl break even considering the cost of the E85. dont bother.
Old 03-14-2011, 09:26 PM
Ravenwood Ranch
Damn ok !!
Old 03-16-2011, 10:44 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Ethanol is corrosive and at levels much over 10% will start eating away at your fuel system. Flex fuel vehicles have fuel system components that are designed to cope with the ethanol as well as you need to increase the injector pulse and move the timing to get the same power output from e85 as you do Gasoline. E85 has a much lower BTU output so it takes a lot more e85 to be injected into the cylinders.
This is why if you look at a window sticker of a flex fuel vehicle, the miles per tank is considerably lower on e85.
Short answer, NO
bluegroove
1983 - 2012 Ranger & B-Series
17
08-09-2019 04:08 AM
640 CI Aluminum FORD
2009 - 2014 F150
35
06-29-2016 01:33 PM
KP1001
Modular V10 (6.8l)
05-27-2016 09:57 AM
tralfamadorian
2010 - 2014 Ford SVT F150 Raptor
09-22-2010 10:03 AM
staysbroken
Alternative Fuels, Hybrids & Mileage
17
09-10-2007 08:06 PM
Quick Reply: 01 F150. can i use e85?
