Torque specs for front wheel bearings??
Brake Rotor (Brake Disc)
Removal & Installation
Front
To Remove:
Remove the front disc brake caliper anchor plate.
On 4x4 vehicles ONLY: Remove the brake disc.
On 4x2 vehicles ONLY: Remove the brake disc and hub.
If necessary on 4x2 vehicles, resurface the brake disc and hub.
To Install:
On 4x4 vehicles ONLY: Clean the brake disc then place it on the wheel hub.
On 4x2 vehicles ONLY: Clean and examine the front wheel bearings and the brake disc and hub. Next, lubricate the front wheel bearings with the correct type of grease and install a new wheel hub grease seal then install the brake disc and hub.
Tighten the spindle nut as you turn the brake disc and hub.
Torque to 21 ft-lb (28.5 Nm).
Loosen the spindle nut by turning counterclockwise 175°.
Tighten the spindle nut while rotating the brake disc and hub.
Torque to 17 in-lb (2 Nm).
On 4x2 vehicles ONLY: Install the nut retainer, cotter pin, and hub grease cap.
Install the front disc brake caliper anchor plate.
Front
To Remove:
To Install:
