speed density chip
speed density chip
ok, so I have the K & n filter, insulated intake, headers, it's an '89 F250 HD, 460 C-6 auto, and I'm considering an upgraded Speed density cam, it sounds like I'll need a custom program? Do you also need the cam specs for this? I use this truck for towing a 5th wheel, and playing around town. Thanks, Bruce
speed density chip
Been looking at the following. Comp Cams Grind # XE256H-14 specs at .50 are int/exh 212/219 lift .490/.495 LSA 114 deg. also been looking at Crane Cams 35655-16 adjustable kit for roller rockers(no machine work). or possible 36806-16 which is their roller bearing kit to replace the solid stop fulcrum, which uses stock rockers.
Any thoughts on these items would be appreciated. Thanks.
tsi9973
04-14-2017 09:54 AM
ryanklumpkin
07-30-2016 08:23 PM
MR KROGOTH
03-05-2016 10:31 PM
Bugzturbo
05-22-2008 12:02 PM
