vibrations between 65 and 70 MPH
here is the problem:
between the speeds of 63-71 MPH my truck has a pretty bad vibration. if you get up to about 75 it will smooth back out. at first I though that my tires just needed balancing. well I just put a new set on and the truck still vibrates. I have recently replaced the U-joints on the drive shaft and the rear axle bearings. it is somewhere in the drivetrain and not the engine because I can put the tranny in neutral going down hill and it will still vibrate.
any other ideas?
any other ideas?
I had a problem similar to this in my 91 F150, around 70 to 75 it would vibrate, i also replaced the U Joints thinking that was the case, which it wasnt. I had my transmission flushed and two days later it died. I brought it to my mechanic and he told me that the vibration is the clutch in the transmission slipping. Hopefully that's not the case for you but i've heard the same thing from others and that's what their problem was as well.
expo54bx
1997-2006 Expedition & Navigator
10-02-2010 12:52 PM
zeppln1
09-03-2003 07:47 PM
