Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Large Truck
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
  #1 (permalink)
Old 03-10-2011, 11:27 AM
80broncoman 80broncoman is offline
Garage is empty, add now
80broncoman is gaining momentum as a positive member of FTE.
My F-700 RV/jeep transport build thread
I bought a F-700 last fall.
Click the image to open in full size.
Before the longer frame rails
Clamped in place
welded in place 19 foot 6 inchs of frame now
My high tech alignment tools
Click the image to open in full size.[/
__________________
GM=Got Mechanic?
77 F-150 4X4 400/4sp
80 Bronc 300/4sp
89 F-450 7.3/5sp rollback
94 F-700 5.9/6spd (camper/hauler project)
  #2 (permalink)
Old 03-10-2011, 11:38 AM
Formy inspiration See this thread:
Po mans Toy Hauler project - Pirate4x4.Com Bulletin Board
The floor of the box is 20 feet long. The ceilng is 24 foot long.
There is a lot of work ahead.
Plans are for:
First remove box from uhaul truck install on mine.
Then convert to RV use
build tray for queen size bed (60x80) and mount above cab with ladder.
Install fridge, microwave, foldable table and chairs.
install box frame for genset and inverter.
install extra fuel tank??
Then get inspection for RV plates.
Then build ramps
The truck, box and jeep should weigh about 19K-21K
GVW is 32.7K so it should be able to tow another 2 Jeeps on a trailer if I wanted.
Just your usual U-haul box
Out with old and dead
up on bolcks
in with the good
praying for no wind ray:
and finally bolted down
the bed (Queen size) is now bolted in place.
The microwave is bolted in its bracket now as well.
the microwave bracket with rubber islolaters.
More pics and info to follow
__________________
GM=Got Mechanic?
80 Bronc 300/4sp
  #3 (permalink)
Old 03-10-2011, 05:02 PM
danger fx4 ranger danger fx4 ranger is offline
danger fx4 ranger is starting off with a positive reputation.
What did you do with the old GMC?
  #4 (permalink)
Old 03-11-2011, 07:56 PM
Quote:
I just moved to the back of thier lot. I didn't buy it. I only bought the U-haulbox.
The GMC needs a crank kit.(366V8)
If you want I could put you touch with the owner. PM me if so.
__________________
GM=Got Mechanic?
80 Bronc 300/4sp
  #5 (permalink)
Old 03-12-2011, 01:29 AM
rummur s.c.'s Avatar
rummur s.c. rummur s.c. is offline
1966 Ford F-850
rummur s.c. is gaining momentum as a positive member of FTE.
Whats with those chevy medium duty engines? They're always loosing their bottom ends..
Cool looking truck though. Amazing how much better the ford looks then the chev.
what kinda mileage do you expect? Whats the ratio in your rear axle?
Not gonna paint the inside of your box?
  #6 (permalink)
Old 03-12-2011, 07:50 AM
1 it a gas bowtie(with 200k) what do you really expect?
2 mileage?? I have no idea yet but it has to be better then a low geared gas u-haul.
3 mine has a 5.29, NO OD, and 41.3 inch tall tires.
I'm planning on useing 3.90 and 36 inch tire for a overall 18 percent reduction from the 5.29 and 41.3inch tires.
Yes the painting on the inside is allmost done.
I'm gonna post more pics as I get more done.
__________________
GM=Got Mechanic?
80 Bronc 300/4sp
  #7 (permalink)
Old 03-14-2011, 09:42 AM
I made quite a bit of progress this weekend.
Installed the U-haul taillight harness.
Ran a 14-2 wire from front to the tailights to put a 110V outlet under the taillights.
Fitted the main part of the hitch for a reciever tube.
insulated about 2/3rds of the wall area that are getting insulation.
added another layer of sound deadner to the firewall areas(duct seal)
Ran a set of speaker wires.
painted more of the inside.
Bought 2 windows (24X22) on Fleabay for the "upstairs" Bunk area. I now have 3 windows , Now I only need one more larger window and a entry door.
Figured out that u-haul uses 2 completly seperate wire for clearence lights. Very odd.
And one step back,
Broke the only blade I had on my Chop saw.
__________________
GM=Got Mechanic?
80 Bronc 300/4sp
  #8 (permalink)
Old 05-22-2011, 11:23 AM
I bought the last window for a total of four. Now i just need a door.
THe truck is at a friends shop getting the rear 3.70 gears installed right now.
I made the bracket to hang the spare tire/whell off of.
I scored some free stuff that i was looking for.
__________________
GM=Got Mechanic?
80 Bronc 300/4sp
  #9 (permalink)
Old 05-22-2011, 11:34 AM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
1948 Ford F-Series Pickup
havi has a great reputation on FTE.havi has a great reputation on FTE.havi has a great reputation on FTE.havi has a great reputation on FTE.havi has a great reputation on FTE.
Havi Proprietor
Sweet! Someday I hope to make a camper out of an old truck, too.
__________________
1948 F1 RIP Terry
1949 F6 Uncle's old truck
1999 Ranger ext. cab 4x4 wife's DD
1998 F150 XL ext. cab 4x4 DD
  #10 (permalink)
Old 06-21-2011, 04:09 PM
well here is some more progress
the inside
the hole is complete
Window test fitted, but window needs drilled and I need to buy sealer to complete install.
Passenger side window installed
The drivers side is done with its two windows
__________________
GM=Got Mechanic?
80 Bronc 300/4sp
  #11 (permalink)
Old 07-03-2011, 09:10 PM
In the last week I installed my extra 50 gallon fuel tank. I'm leaving it empty till I get going on my big trip and get to OK or TX where diesel is much cheaper. Not knowing how clean the inside is I installed a filter in the transfer line.
Yesterday I went to a lion's club fundraiser cruise-in with the big truck. A guy I've known for 25 years walked over and looked at my truck and offered me a used RV door for $10.
I went and looked at it today and I told him If he let me take the screen door with it I'd give $20. (new doors are $512)
AND I'm getting 2 more windows for anthoer $20
only small downside is that I have to remove this stuff my self.
These parts are on a later model Airstream and are of high quality.
I am overjoyed to find this stuff.
It turned out stopping by and giving some funds to the lions club was VERY GOOD thing to do.
Tuesday the new rear tires are supposed to be in. and wednesday they will get installed.
__________________
GM=Got Mechanic?
80 Bronc 300/4sp
  #12 (permalink)
Old 07-07-2011, 05:00 PM
7-07-11 Got the new rear tires on the big truck yesterday. last night on the drive home I checked the new speedo calibration with a stopwatch and found it to be 100% correct @ 60MPH.
Today i went and removed the 2 new (to me) RV windows i bought and almost got the door and door frame removed. I'm going back after it tomorrow.
7-19-11
I got the my 4th window in yesterday. it will be my last windoW before my vacation in 4 weeks.
And here is the door I bought (for $20)
Click the image to open in full size.[/quote]
__________________
GM=Got Mechanic?
80 Bronc 300/4sp
  #13 (permalink)
Old 07-31-2011, 07:58 PM
Well i went and did my MPG test run and came out MUCH better than I thought I would.
I did a round trip from Mid town kroger fuel stop in Ashland Ky to Grayson Ky and back.
I did not try to drive for max MPG Ii ran 65-68on flat ground and held to floor on the hills. It only dropped 4 MPH on any of the hills.
I drove it like this to get a worse case idea of MPG.
I made sure to use the same pump and fill to same point (lower lip of filler pipe)
The result was 49.4 miles and 4.2 gallons of fuel used for 11.7 MPG.
I had heard these 12V cummins got good milage, but I didn't know it was this good. I think this is good mileage considering the over 13K empty weight, and the bluntness of the box.
I was told the higher gears would pay for themselves. It looks like they will.
__________________
GM=Got Mechanic?
80 Bronc 300/4sp
  #14 (permalink)
Old 08-01-2011, 12:19 AM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to beholdBradyCouchman is a splendid one to behold
just keeping an eye on this one!
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed DD
SoCal FTE Member
  #15 (permalink)
Old 08-01-2011, 12:07 PM
framerboy framerboy is offline
framerboy is starting off with a positive reputation.
I have been enjoying this thread. I admire the mechanical abilities of a lot of the posters here at FTE. I remember one thread where a young guy was attempting to take a V-10 from a wrecked van and put it into a F-150. Any one know what happened to that project?
__________________
1993 F-250 Supercab 4x4 460 5spd.
Tags
366, built, camper, f700, ford, gmc, haul, hauling, home, jeep, rampback, rv, transport, transporter, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
