460 head....D3ve Or D9ve
Old 10-24-2018, 09:25 AM
black & blue 78/9's Avatar
black & blue 78/9
black & blue 78/9 is offline
My current 460 is sitting on the floor waiting for the engine project to start.
It is a 1979 E350 460.
My local jy brought in a 12/73 F250 4x2 Lariat XLT with a 460. Should I grab the D3VE heads off of the 12/73 460 or stay with the 79 heads?
My plans for the engine arr to swap it into my 79 Bronco. I'm not looking for big power but a respectable 350-400 horse. Will the D3VE head raise the c/r better without as much machining work? Or not enough performance increase for the cost?
Thanks to all that have shared their knowledge.
Old 10-24-2018, 11:44 AM
dogdays's Avatar
dogdays
dogdays is offline
I think the heads are the same. Others will either agree or bash this opinion.
R.
Old 10-24-2018, 12:39 PM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
Heads are functionally the same. And to be honest neither...... Source a set of D0VE's
Old 10-25-2018, 12:21 AM
SDDL-UP's Avatar
SDDL-UP
SDDL-UP is offline
For 350-400HP I'd keep the 400! I actually have such a 400 in my 78 Bronco now. More power is always a good thing so if you want the 460 then go for it.
I thought 400 exhaust ports were terrible until I looked at the flow numbers on a 460 head - ouch! Listen to those that know the 460!
Old 10-25-2018, 03:34 AM
matthewq4b's Avatar
matthewq4b
Yup totally agree, the exhaust ports on the 460 are horrific and should be addressed even on a stock motor it is worth some ponies. The 400's handicap is crap cam timing and bad cams and only ever offered in a 2BBL. The 400's bottom end (rods ) are actually stronger than the late 70's 460's.
Old 10-26-2018, 12:04 AM
black & blue 78/9
Thanks
Thanks guys about the heads. I knew the exhaust side had a bump that needd to be worked on. I didn't know about the 400 con/rods being stronger. If its not to much more work to break 425hp and about the same money, then I will go that route.
Old 10-26-2018, 07:36 AM
matthewq4b's Avatar
matthewq4b
To put things in perspective of the untapped power potential off the 400 in 1971 the 351C with a 4V carb and heads, with 9.0:1 compression ratio was rated at 285 hp @ 5400 rpm, and 370 Ft Lbs of Torque at @3400
Where as the 400 with a 2 BBL carb and the 2 BBL heads and a milder cam with a 9.0:1 compression ratio was rated at 260 hp @ 4400 rpm. and 400 Ft Lbs of Torque at @2200 RPM.
The 400's original heads will need some porting work to make 425HP. I would try to source a set of early 2V heads either Cleveland or 400 any Pre D5 head, in 75 when the 351M was introduced the 2V casting was changed to a more restrictive exhaust port.
Old 10-27-2018, 10:54 AM
bryanmartin's Avatar
bryanmartin
bryanmartin is offline
Any head can be modified for better power output, but I agree, I'd hold out for some D0VE heads. I have those on my 460 powered Bronco and they're awesome. They do have the Thermactair bosses in the exhaust port, but you can rip those things all the way out of there with a grinder and not even come close to any water jackets.
Old 10-27-2018, 11:12 AM
black & blue 78/9
Pics
Anyone have pictures of the offending bump and where/how much to grind away? I remember seeing a pictures years ago but didnt that much attention because I wasn't looking for that. Just reading to take up time back then.
Old 10-27-2018, 11:44 AM
somethingclever's Avatar
somethingclever
somethingclever is offline
Reincarnation automotive has pics
Old 10-27-2018, 12:07 PM
matthewq4b's Avatar
matthewq4b
Exhaust port cross sections ford 460 iron heads
Here you go.
You can see how restrictive the 385 Series port really is and it is bumps, the thermatic and the side wall.
rwjr
11-26-2008 09:32 AM
Handegard
06-21-2007 04:21 AM
JoeSwing78
01-30-2006 03:53 AM
chrowen
05-09-2003 10:17 PM
Quick Reply: 460 head....D3ve Or D9ve
