flexplate id c80p-c
Old 03-07-2011, 11:58 AM
doowop45's Avatar
doowop45
doowop45 is offline
flexplate id c80p-c
I have a flexplate marked c80p-c or c8op-c. Can someone please tell me what it came off of? Will it fit my 1993 302? Is it a 1968? HELP!
Old 03-07-2011, 03:03 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is online now
no it will not work on a 93 motor. the imbalance is incorrect.
Old 03-07-2011, 06:26 PM
doowop45's Avatar
doowop45
doowop45 is offline
Thank you. That is very helpful. Do you by chance know what it originally would have fit?
Old 03-07-2011, 09:56 PM
Kemicalburns
sorry i dont. what i know is any 302 before 1982 had a 28oz imbalance like the 351w.
any 302 after 82/83 had a 50oz imbalance.
what tranny are you planning to have behind the 93 5.0?
Old 03-08-2011, 02:31 AM
doowop45's Avatar
doowop45
doowop45 is offline
I have an 83 C6 transmission for it. So any flywheel for a C6 trans for a 302 made after 82/83 will have the correct weight? How did you know what the weight was on my flexplate so that I may identify the one I do need when I find one? Thank you again.
Old 03-08-2011, 10:10 AM
Kemicalburns
honestly i would just go buy one new. you will spend less then $75 bucks and the ring gear and such will be brand new, plus you will know exactly what you need. I have gone to wrecking yards and they tend to not know what most flexplates are either. but if you must go any flexplate from a 93 5.0/e4od tranny would work.
you want 50oz imbalance, C6/E40d are the same
C4/AOD are the same
good luck
Old 03-09-2011, 02:31 AM
doowop45's Avatar
doowop45
doowop45 is offline
Thank you. You have been very helpful.
Old 03-13-2011, 10:24 AM
restoringmy46's Avatar
restoringmy46
restoringmy46 is offline
I need a new flexplate to for a 91 302 motor with a 79 C6 behind it. Where did or can you get a new flexplate for $74 bucks. Thanks Scott
Old 03-13-2011, 11:20 AM
restoringmy46
I just called AutoZone and they can get me a new flexplate for $50 bucks. I didnt know they was that cheap. I know $50 bucks really isnt cheap money to throw around but I thought a flexplate would be higher than that. Thanks for saying that bc it helped me out today. Scott
jrockdiddy
17
09-25-2018 04:03 AM
ToddOuzts
05-16-2017 10:19 PM
Coastal68
07-10-2016 06:09 AM
GreatNorthWoods
16
04-20-2011 04:29 PM
Quick Reply: flexplate id c80p-c
