351w, C6, how many teeth on flexplate - Ford Truck Enthusiasts Forums
Old 12-30-2013, 08:11 PM
jrockdiddy's Avatar
jrockdiddy
jrockdiddy is offline
jrockdiddy is a splendid one to beholdjrockdiddy is a splendid one to beholdjrockdiddy is a splendid one to beholdjrockdiddy is a splendid one to beholdjrockdiddy is a splendid one to beholdjrockdiddy is a splendid one to behold
Want to purchase a starter, not sure how many teeth are on flexplate. The C6 is already bolted to the motor. How can tell without unbolting the transmission?
Old 12-31-2013, 12:27 AM
52 Merc's Avatar
52 Merc
52 Merc is online now
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Probably the most accurate way would be to drop the starter (if it is still there), make a mark on one tooth and turn the engine over one time by hand, counting the teeth as they go by through the starter hole. If there's an inspection plate on at the bottom of the bellhousing, that would make counting even easier. Don't forget to remember if you counted the marked tooth or not. There's too many chances for error if you try to guess without knowing the exact application of your parts.
Old 01-01-2014, 04:45 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1969/96 351W: Two possible A/T flywheels, both have 164 teeth.
Old 01-01-2014, 05:42 AM
Normalbloke
Normalbloke is offline
Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.
I was going to say 164. Doesn't the c6 have a removeable inspection plate on the block mid plate that should allow you to verify without removing even the starter? I believe it's just held in with 3 self tapping screws..
( as 52 Merc just said!)
Sorry 52 Merc, I didn't read your thread fully.
Old 01-01-2014, 07:57 PM
jrockdiddy's Avatar
jrockdiddy
Here's the only spot I can see to count teeth. I'm assuming this is where I mount the starter too. ( probably a stupid question)
Old 01-01-2014, 07:58 PM
jrockdiddy's Avatar
jrockdiddy
Old 01-01-2014, 08:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
How many does it have?
Old 01-01-2014, 08:41 PM
52 Merc's Avatar
52 Merc
Yes, that's the spot where the starter mounts.
Old 01-02-2014, 11:04 AM
jrockdiddy's Avatar
jrockdiddy
Gonna count today. I work evenings so usually when I do my postings I'm at work. If I'm home, I usually have a "honey do" list a mile long
Old 09-22-2018, 07:48 AM
Kurttb1
Kurttb1 is offline
Kurttb1 is gaining momentum as a positive member of FTE.
Trying to find the right starter for my 1969 Ford F-250 Camper Special w 1975 (I think) 390. was looking to get one of the mini-starters to get space for my headers. On some starters they say it works for 390, but my Truck doesn't show up in the models and some have listings of how many teeth are on the flywheel.
After I bought the Truck, the engine blew-up so I replaced the engine with another 390 I never knew if it came from a car or a truck I don't know, and I can vaguely remember maybe from a 1975. When we changed the engine we used the Flexplate and Tranny C6 that was in the truck when I bought it.
Will all the 390's use the same starter? Will my frame or crossmember get in the way of some starters? My main issue is that my starter died and I wanted to get one which would not touch the headers which are now (1/8) inch or less clearance.
Old 09-23-2018, 09:57 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
CharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant future
The tooth count on the flexplate does not matter, the starter is the same for both the 157 and the 164.
Old 09-23-2018, 11:06 AM
Smitty49's Avatar
Smitty49
Smitty49 is offline
Smitty49 has a very good reputation on FTE.Smitty49 has a very good reputation on FTE.Smitty49 has a very good reputation on FTE.Smitty49 has a very good reputation on FTE.
The tooth count as already stated is 164 although the Torque converter offset is different between the C6 and the C4
Old 09-24-2018, 08:17 AM
BlueOvalRage's Avatar
BlueOvalRage
BlueOvalRage is offline
BlueOvalRage has a very good reputation on FTE.BlueOvalRage has a very good reputation on FTE.BlueOvalRage has a very good reputation on FTE.BlueOvalRage has a very good reputation on FTE.
As was mentioned, tooth count doesn't matter on the starter - but the transmission type does. There were some exceptions, but the general guideline with 2-bolt Ford starters is that automatic transmissions had one snout length and manual transmission used another. If you're looking for a small starter for header clearance, ask for one for a 1994 F-150 with a 5.0L and an automatic. It should fit and function with your 390 and C6 just fine and is the smallest OE starter available.
Old 09-24-2018, 10:53 AM
NumberDummy
1963/76 FE (352/360/390/406/410/427/428) 3 mounting holes starter is the same .. A/T or M/T makes no difference, Passenger Car or F100/350 makes no difference.
1958/62 FE starter (also 3 mounting holes) uses the HUGE Bendix inertia starter drive.
C5AZ-6375-D .. A/T Flexplate / Obsolete
1965/67 F100/350 352 with MX Cruise-O-Matic; 1968/76 F100/350 360/390 C6.
1965/67 Passenger Car 352/390 with FX/MX Cruise-O-Matic; 1967/71 Passenger Car 390 C6.
1958/64 FE & 1966/70 410/428 flexplates are not the same.
Old 09-24-2018, 11:03 AM
52 Merc's Avatar
52 Merc
Actually, that's incorrect. FE starters have 3 mounting bolts, and are unique to the application. Small block starters have 2 mount bolts and won't fit.
Quick Reply: 351w, C6, how many teeth on flexplate
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
