controller problems
controller problems
I just bought a tekonsha voyager and its on my 78 ford so i had to wire it all (no plug and play) and it all works but when i press my brake pedal nothing happens i can slide the manual slide bar and the green light turns red. i hooked my red wire (for the brake pedal) up to my green wire (right turn/brakes) my dad has the same brake controller and when you hit the brakes it switches form green to red. does anyone know what the problem is?
I am stumped on that one...I hope you figure it out...and let us know what you did...
This is a shot in the dark here...if the trailer brakes are not receiving electric signal from controller or controller is not sensing the brakes...you may have a broken line going to the brakes on the trailer or a bad connection at the plug...That's all I can think of
Sorry man,
Pete
Sorry man,
Pete
i figured it out i had a bad connection that hooks up for the brakes but i still cant figure out whats up with the cold side wire for the brakes, on the turn sigonal wire it was just to test it so i could see if it worked does anyone know witch wire it would be, there are two wires that go to my brake pedal and neither one tests hot. so i dont know what to do there.
Check Fuses
If the fuse is out and you replace it and the fuse blows when you hit the brake pedal you have a dead short somewhere going to the taillights...Also...I have found over the years that it is a good idea to check the grounds also...just for fun!
I know this is getting ahead with the fuse bit, I am just trying to think ahead if that fuse thing happens to you..Good luck man and like I said...Let us know how it turns out. You can do it!
Pete
it depends on how you're testing them...
with a grounding switch, it will have an impedance between the voltage source and the measuring tool. If the tool does not have sufficient impedance to prevent current flow you will end up measuring the voltage AFTER the drop from the load... which will not measure as 12v. Similar results will show up if you're using a test light... it might be lighting, but very dimly and not noticeable.
My experience with big 3 electrical systems in the 1970's is that they really liked to use grounding switches (door switches ground the lighting when the door opens, brake switch grounds the lighting when the pedal is depressed, horn button grounds horn relay, etc...)
