Looking for an ignition upgrade.
Hello all it's been a while since I posted. I just got my 82 back together I pulled the bed off repainted everything and rebuilt the rear axle. It drives like a dream now! I have a new question I want to upgrade to a new ignition system. The one it has now it still works... But... The wires are a mess all the connectors are cracked and broken. Plugs are disconnected the smog pump line has a sparkplug shoved in it. I want to get rid of the excess as much as possible. Right now its a big mess of goobly glop. Redneck enginered to the max. Is there a kit or a simpler system that can be used instead of all of these wire bundles everywhere? Thanks for reading and responses.
Yes, I use the D.U.I distributor from Performance Distributors. It is a one piece unit, distributor, ignition coil, and box. There are 2 wires to connect, power and tach.
They ask you some questions about your vehicle and then build and calibrate it to your needs. Mine runs great and the trick fires up the first time every time.
It's not cheap but when you add up all the parts for a regular ignition system the cost is pretty close.
Ford DUI - Street/Strip Version
You might also check into Summit or MustangsUnlimited.com for their "H.E.I." style distributors. Similar design to the GM HEI coil-over-cap setup. They're a great upgrade on a 302 or 351W and a direct bolt-in using just two wires (ignition power and tach). They can be had for between $150 and $250 depending on the brand and what sales they have going at the moment.
Change for changes sake??
The DuraSpark II ignition system is a fine system, and worth the effort to restore if your harness has gotten out of whack. A DSII module has advantages that the "others" don't, like being able to retard the timing for easier starts when warm.
Performance Distributors makes a fine dist, but you get what you pay for, and you'll pay a premium with them. I am currently considering their DSII style dist for my own engine. I moved away from the DSII before I knew better, and now I want to go back. I collected a harness from the JY, and have now completly rebuilt it. Now it's all nice and pretty!
Just waiting for a few extra bucks...
http://www.performancedistributors.c...dduraspark.htm
on
The plug at my distributor was falling aprt so before it left me sitting on the side of the road I just cut the connector out and soldered the wires together. I have done the same at the module side on other trucks. It just makes it a little harder to replace parts if they go bad, but I think its worth it to eliminate a potential problem. A new harness would be a better option, but this was free!!
Sorry, I think of reducing the amount of wires running everywhere in my engine bay as an upgrade. Anything that increases performance or looks of my cars is an "upgrade" to me.
Getting rid of that bundle and box on the fender well makes the engine bay look a lot cleaner, and has less things to snag or damage while I'm working around in there.
If you don't want the ignition module on your fender well, I'd love to have a spare. PM me and we'll work something out on it, ok?
I appriciate all of the rapid responses although now I have two new questions. Question 1 what is the MSD 6AL box and can I use this with my current setup. Eliminating the original wiring The reason being I do a lot of high rpm mud bogging and the rev limiter option is atractive to me, I don't want to spin a bearing. Question 2 what is the giant box under my drivers seat? Thanks a bunch all I appriciate it.
Sounds like you've got a stock motor. If your current ignition is a Duraspark II you won't see any benefit from an MSD box or distributor. Duraspark II distributors are pretty easy to recurve and you can get adjustable vacuum advance cans for them. Replacement ignition boxes are cheap and readily available used or new. I'm pretty sure I've seen new plugs with pigtails for a few bucks. Worst case just find generic weatherproof plugs with the corret number of pins. Repair what you have, your money is better spent in other areas if you want more power.
With a stock cam, no port work on the heads, and no headers along with whatever cheapy dual plane the Summit brand is and that knockoff carb you're not gonna be spinning to the point where your ignition will be cutting out.
If you're not worried about the ignition cutting out then why do you want to upgrade it? Duraspark II is more than adequate for a stock or mild to moderate engine. Unless you have a whole lot of compression and spin to the moon, you're not gonna have trouble with it. The time and money can be better spent in other areas.
