Fuel injector copper crush ring
03-06-2011, 01:41 PM
on
I am trying to be very careful with my fuel injectors and not damage them. I am probably being too careful. What is the trick to getting the copper crush ring off without damaging the tip of the injector?
03-06-2011, 02:21 PM
Just slide it off, it fits pretty tightly. The holes in the tip are out on the angled part, so scraping the washer down the sides won't hurt anything.
03-06-2011, 03:12 PM
i used a razor blade to get mine off. or at least get it started.
03-06-2011, 03:52 PM
Quote:
Originally Posted by
BLADE35
x's 2
Then I used either a 5/16's or 8mm deep socket to tap the new washers back on
03-06-2011, 04:29 PM
pocket knife. to install them push them on with a 8mm deep 1/4" drive socket
on
Got it thanks.
I used a tiny screw driver.
They are pressed down tight.
Josh Krynski
1999 to 2016 Super Duty
06-11-2017 07:19 PM
3000gtman
02-01-2017 06:15 PM
Colton Haight
13
10-02-2016 12:18 PM
farmert
15
03-15-2014 08:25 AM
den052
03-30-2012 12:27 PM
60 ,
60l ,
73 ,
copper ,
crush ,
diesel ,
drop ,
f250 ,
ford ,
fuel ,
injector ,
install ,
powerstroke ,
ring ,
washer ,
washers
