Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.7L Power Stroke Diesel 2011-2012 Ford Powerstroke 6.7 L turbo diesel engine SPONSORED BY:
  #16 (permalink)
Old 03-10-2011, 10:23 AM
Biggziff's Avatar
Biggziff Biggziff is offline
Garage is empty, add now
Biggziff is gaining momentum as a positive member of FTE.Biggziff is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by dixoncity View Post
Can someone explain what "Road Forcing" the tires mean?
Hunter GSP9700 Wheel vibration Control System solves wheel vibration and tire pull problems that balancers and aligners can
__________________
2011 F350 CC 6.7
  #17 (permalink)
Old 10-27-2011, 08:15 AM
2011 SUPER DUTY6.7 L 2011 SUPER DUTY6.7 L is offline
2011 Ford F-250
2011 SUPER DUTY6.7 L is starting off with a positive reputation.
Vibration 40-45
Well folks ! I love my truck and would really like it fixed. On 9/30/2011 Ford customer relations told me they were done working on my truck for this problem. To just give the history, vibrates between 40-45 mph, I have tried everything I can possibly think of to get rid of it. The dealership has been great :16 tires,8 new wheels,new rear driveshaft,new rotors,tranny reflashed and updated,diff. apart 3 times,shaved and roadforced the tires(michelins now).
Ford has told me it is within specs and a natural characteristic of the f250
to vibrate.
Sorry Ford not right! I have been very patient throughout this ordeal, but telling me your done was the wrong reply.
I have now filed Lemon Law on this truck after them keeping it 22 days this last time, over 30 plus in total. The legal team took the case and will be pursuing Ford.
I really hate doing this, and still looking for answers before I get into another truck.
2011 f250 lwb crew cab(pure stock) 12,500 miles
Lariat/auto/4x4/18" wheels
3:31 gears
tow 11,500 (loaded) 34ft TT occas.
Last edited by 2011 SUPER DUTY6.7 L; 10-27-2011 at 08:39 AM. Reason: addition info
  #18 (permalink)
Old 10-27-2011, 08:42 AM
2011 Ford F-250
According to what I have been told, it is a simulated pressure balancing applied to the tires.
  #19 (permalink)
Old 10-27-2011, 09:24 AM
cford716 cford716 is offline
cford716 is gaining momentum as a positive member of FTE.
Not sure if this will help but this sounds exactly what was happening recently with my sons Jeep. We put larger tires and wheels on it, 32" so nothing too big, Goodyear Silent Armour. Immediately had a vibration between 40-45. Rebalanced, rotated, aligned, had the entire front end and steering checked and finally Road Force balanced them, all with no change. Finally got Goodyear to work with me and swapped the tires to Goodyear Duratracs. Vibration went away. Only thing we can figure was the that setup with that tire just didn't work with the vehicle.
Do you have the stock tires on? Either way if you can I would swap to a different brand or size tire even if you are running the stock ones. Just to know.
Good luck, I know how frustrating it is.
  #20 (permalink)
Old 10-27-2011, 10:33 AM
p12483 p12483 is offline
2011 Ford F-250
p12483 is starting off with a positive reputation.
Unfortunately, there are several members stating they are having this issue. Once member even test drove several 2012's with different packages and all had it.. so it could just a be a characteristic. I get the 49 and 74 mph vibration and that's it, other than that truck is great. I have never towed anything either. The only thing i can think of is check motor mounts. One member checked his and found the nuts were about to fall off.
  #21 (permalink)
Old 10-27-2011, 10:59 AM
CascadeF250's Avatar
CascadeF250 CascadeF250 is offline
2011 Ford F-250
CascadeF250 is gaining momentum as a positive member of FTE.
to vibrate.
3:31 gears
I have exactly the same truck with no vibration problem at any speed. I have 275/70 18inch contententals on it from the factory. I don't particularly like the tires but they are wearing OK and no vibrations. I hope you are able to resolve your situation to your satisfaction. This sounds like another case that Ford has not been stellar in there performance. If they cannot fix the problem then Ford should have offered to repace the truck themselves. Has the same dealer been doing all of the work with "competent" technicians . Good luck.
  #22 (permalink)
Old 11-09-2011, 10:15 AM
2011 Ford F-250
Well got the letter from Ford legal analyst on 11/5/2011 says the case is considered closed and it is comparable to other units.
I quote "the vibration is a normal characteristic of typical operation of this vehicle and that the vehicle is operating within Ford specifications".
Sorry Ford not done with you yet!
  #23 (permalink)
Old 11-09-2011, 11:08 AM
Quote:
Like I said earlier, it may be the tire combination like was the problem my son had. For a lack of what other direction to go I would suggest swapping to the 18" wheels and see what happens. Like he said above, same vehicle with 18" no vibration. I also have 250 CC SB with 18's no vibration. I don't recall anyone having this problem with 18" wheels, only the 20's.
Just a thought and just labor cost if the dealership will work with you, swap them from a truck on the lot. If it works then you can fight it out with Ford that it is not a "characteristic of the truck", it is caused by their tire wheel combination. Also, if it was a characteristic of the truck we would all have it and we don't.
Good luck and keep us updated.
  #24 (permalink)
Old 11-09-2011, 12:10 PM
2011 Ford F-250
Already done that 2 times. Found out through Discount Tire there was a problem with the Continentals from O.E.,tried thre sets of them now has Michelins on it with another set of wheels.
  #25 (permalink)
Old 11-10-2011, 12:49 AM
Just want to clarify, your truck came with the 20" wheels but you have tried it with the 18" wheels and it still has the vibration? I also have the Continentals.
  #26 (permalink)
Old 11-10-2011, 05:51 PM
2011 Ford F-250
Quote:
Well it came with the 18" continentals and we tried three sets, then they took another brand new truck and swapped tire/wheel assemblies complete. Still 18" wheels and michelins now.
  #27 (permalink)
Old 12-22-2011, 01:15 PM
hollywood27 hollywood27 is offline
hollywood27 is starting off with a positive reputation.
Vibration from drive train
Anyone find a solution to the vibrations on the new super duty's. I have a 2012 F-350 6.7 that has had a vibration from day 1. You can feel it in the floor at all speeds and very noticable at highway speeds. I've had the truck 3 weeks and it has been in the shop over 2 weeks. They admit that something is wrong but after changing drivelines, u joints, yokes and tires and wheels the vibration and noise are still there. Don't know what to do.
Thanks Ernie
  #28 (permalink)
Old 12-22-2011, 02:33 PM
OffroadSD OffroadSD is offline
OffroadSD is starting off with a positive reputation.
A couple people of asked about the e-lockers but I have never seen a response to see if that maybe the issue.
I recently leveled my truck and now I notice the vibration problem between 45-48 mph. I have bigger tires as well. I usually can let off the gas for a few seconds and let it roll and get back on the gas and most of the time the vibration stops. Mine is not really bad but noticeable, so far I can live with it. Not sure where the problem is at, hopefully someone figures it out.
  #29 (permalink)
Old 12-22-2011, 04:44 PM
marchare011's Avatar
marchare011 marchare011 is offline
marchare011 is a splendid one to beholdmarchare011 is a splendid one to beholdmarchare011 is a splendid one to beholdmarchare011 is a splendid one to beholdmarchare011 is a splendid one to beholdmarchare011 is a splendid one to beholdmarchare011 is a splendid one to beholdmarchare011 is a splendid one to behold
Quote:
Thanks Ernie
Congrats on the new truck and welcome to FTE!
Hope you get a resolution soon. Just a thought; that 4 wheel drive **** hiding behind your transmission shift lever does point to the 2, right? I don't mean to be a smart a**, I just know that thing is hidden pretty good and is often over-looked.
__________________
Ron,
2011 F-350 6.7 PSD 3:73 FX4 DRW CC Lariat Ultimate
Dark Blue Pearl Metallic, DVD Headrests, Luverne mud flaps, Access Tonneau Cover, EZ Down T/G damper,
2011 Raptor 361LEV Toyhauler 18K, Honda 1800 VTX-C, 2 Arctic Cat 700 TRV's
  #30 (permalink)
Old 12-23-2011, 09:52 AM
2011 Ford F-250
Hollywood, good luck I can definetly relate. Wish I could help with some advise but Ford has done everything possible to include pissing me off now. Its in the lawyers hands now!
Good Luck!!
Tags
2011, 250, 67, complants, dash, diesel, duty, engine, f250, f350, ford, steering, super, vibration, wheel, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
