You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Just wondering what you guys do to test your biodiesel after you make a batch. Going to pick up the system on sunday and want to make a batch to see how it works out.
Thanks guys
Philip Berardi
__________________
Philip Berardi - 2012 F250 Lariat CC SB FX4 - Weather Tech Floor Mats / AVS Vent-Visor / H&S (on the closet shelf until 35k )/DRL/Switch Back Mod
__________________ Matt PAA #117 99.5 F-250 XLT CC SWB 4x4 AUTO Warn M12000 GPR-LED. Foil Delete. 6637. 0.25 Cent. AC. Isspro Dual Pyrometer. AeroForce. FRx. DIY SS Fuel Lines. 03 HeadLights. 4" SS Exhaust. 6.0L Trans Cooler. BTS Tunes. Member On RHN
2001 F-550 auto 73000 miles
Thanks guys
Philip Berardi
First test I do is a preliminary soap test. Shake equal amounts water and biodiesel vigorously in a jar for 10 seconds. At room temp it should separate into two layers in about 20-30 minutes, clear water underneath, and absolutely no layer of anything whatsoever in between. I'll run another wash cycle if it does not meet this criteria. For futher testing I'll do a soap titration to see that I am achieving less than 50ppm soaps. The shake test is the first test however, and lately that's all I have been doing since my oil source and procedures have not varied at all in the past couple years, and perhaps I have become a bit complacent.
My first test for water content after I dry my biodiesel is to put a sample in the fridge until it reaches 45F. If it remains clear, I consider it dry. If there are any wisps or cloudiness I will do a hot pan test on it. Take a hot pan and swipe about a 1/4 teaspoon on it. If it bubbles and/or spatters, then you have moisture. If no reaction other than smoking, then it's dry. There is a further method I will employ called the weigh-heat-weigh method, which involves heating a sample in the microwave and weighing it before and after to see if any moisture evaporated out.
Please keep in mind that my preliminary soap and dryness testing methods are very rudimentary and just a starting point for testing your home brewed biodiesel.
thanks for the info alan....and matt that is where this is posted?
__________________
at first it was on the 99-03 forum, i believe. unless i was on the wrong one? dont know but you are in the right place.
