429 with t18 transmission help.
Old 03-01-2011, 10:12 PM
Oldyeller75's Avatar
Oldyeller75
Oldyeller75 is offline
Hey guys new member. Have been searching and searching for answers on how to pair a 429 and t18 with no avail. First of all is this even possible? Do they make a bell housing that bolts directly to a 385 series engine and a t18? If they do make the bellhousing what else would I need to get to transfer the t18 over? I found a 429 bell housing on eBay with and "x pattern" on the transmission end. Called the guy and he said it would fit a t18 but would like to know for sure if it will fit. Haven't yet dropped the tranny to see what the pattern looks like yet. Thank you for you help and advice!
Jake
Old 03-01-2011, 11:09 PM
co425's Avatar
co425
co425 is offline
A np435 bellhousing wil work if you drill and tap the offset lower left hole. Every thing else is the same.
Old 03-01-2011, 11:48 PM
Oldyeller75
One more thing I'm assuming that it is a t18 cause that's what a friend said it could be. Is it possible that it might be a np435? What did 75 360 4x4s come with stock? Thanks!
Old 03-02-2011, 12:07 AM
co425's Avatar
co425
co425 is offline
Either one. More likely a np435. If it has an aluminum top it's a np435. If it's all cast iron it could be a t18 or 19.
Old 03-02-2011, 01:59 PM
Oldyeller75
Just looked and it is a np435. Also found out that I have a a C9VE-B block with D0VE-C heads which I heard were the best to have. Besides the bell housing, what else do I need to look for? fly wheel, clutch ect.? What other 385 series parts will work with the 429?
Thanks! Jake.
Old 03-02-2011, 09:47 PM
co425's Avatar
co425
co425 is offline
Could be wrong but I am prety sure 429 and 460 clutch, flywheel etc. Are the same.
steve33444
19
08-25-2015 08:49 AM
401477534
16
09-10-2011 04:00 PM
catbird7
Engine Swaps
11-01-2006 04:01 PM
olfordsnstone
11-22-2003 09:19 PM
ford429cu
04-06-2000 02:15 PM
Quick Reply: 429 with t18 transmission help.
