1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Dump trailer charge wire
Old 02-28-2011, 09:21 PM
PineViewlandscape's Avatar
PineViewlandscape
PineViewlandscape is offline
I have a 04 F450 c/c .I want to run a 2/0 guage wire from the battery on the truck directly to the Dump Trailer hydro pump. The trailer is a 10,000lb cap twin cylinder. The only thing that im hung up on is what size circut breaker will I need to run. Any help will be great, Thanks
Old 03-01-2011, 12:17 AM
jefflitzy's Avatar
jefflitzy
jefflitzy is offline
I Ran 4 g for my dump trailer and ran a 150 amp breaker and have not had an issue in 15 years since i got my trailer.
Old 03-01-2011, 11:16 AM
12ozd's Avatar
12ozd
12ozd is offline
I would start by finding out the max amp load for the trailer.
(2/0 wire is probably over kill,2 gauge should be o.k.)
But that would also be determined by the amp rating for the motor.
Old 03-01-2011, 02:21 PM
Sebs's Avatar
Sebs
Sebs is offline
For OO gauge wire the maximum circuit breaker size would be 400A to insure the breaker blows before the wire. Or you can size it for the actual current the pump draws and add about 50 percent more for margin. Just don't exceed 400A. It may be overkill to run 00 wire but you will get more power to the pump by doing it.
Old 03-01-2011, 03:29 PM
PineViewlandscape
The install on the wiring went great, I have strong power going to the solonid , I installed a velvac single pole disconnect with the ground going through the provided hole on the plug handle. A 150amp breaker in line. I think that 2/0 wire is way over kill but it beats a burnt up truck, Thanks to all for the info.
metalcaster
08-18-2016 03:37 PM
AFoster1025
08-24-2011 06:32 PM
skylinekw
Electrical Systems/Wiring
03-24-2010 09:05 AM
ToaDisco
11-28-2009 09:49 PM
Ding
11-02-2005 08:52 PM
Quick Reply: Dump trailer charge wire
