I'm on a couple other forums,and on a fifth wheel forum,some guys were beating up on the 6.0 PSD guys' and a guy recomended getting rid of the factory Ford antifreeze (because of silicates)that plug the EGR,I've also heard about how critical the ph balance is in the 7.3PSD,although the V-10 is of course gas,are there any recomendation or issues running the Ford OEM anti freeze in my'06 V-10,is there anything better,Thanks
I was wondering the same. Coming from owning a 'Burb, I knew of GM's crappy dexcool and I stayed away from that and stayed with the green stuff. I was wondering if Ford's "orange stuff" was the same.
Yeah, I drained out that Dexcool stuff from my mother-in-law's '95 Buick - in 1997. It was horrible to put it mildly. 2 years after it was put in, it looked like they had used straight water with no corrosion inhibitors.
There are all kinds of coolant formulations on the market. From my understanding GMs Dexcool is different than Fords "Gold" coolant. It may have similarities but its not the same. Mine is overdue for a change. Was planning on using Prestone but I'm thinking about putting the Ford Gold back in, its treated me well thus far.
My truck only has 27,000 mis.on it but was thinking of changing because of age,it's the gold stuff and looks great ,but after what I read on the diesels I thought someone on here might have a recomendation ,if there was something better,Thanks
I would put the Cat ELC in it. That's what was recommended to me because of the silicates in the Ford. The V10 might not be as picky as the 6.0, but why take the chance.
Your worrying about a non issue IMO. The EGR system for the 6.0l is completely different and more complex than any EGR system ever put on the 6.8l. No coolant comes into contact with the EGR system on the 6.8l. Some of the diesel guys install coolant filters on the 6.0l and other diesels mainly to remove sand and other matter in the coolant system to keep it out of the EGR system.
The Ford coolant is a HOAT or hybrid OAT coolant which does not have the silicate content of the standard Ethylene Glycol (green) coolant. The OAT and HOAT coolants are longer life coolants that require less frequent changes. That is one reason Ford and many other OEMs use it.
That's kinda strange, I had a 6.0 and put a coolant filter on it after the EGR cooler went south and was replaced under warranty. Even the Ford tech at the dealer said there were silicates in the gold coolant and to switch to Cat ELC. Nice to know about the EGR system on the 6.8, learn something new everyday!
