engine missing under acceleration
I have a 2005 FX4 with a 5.4L.
I have noticed in the past 3 months that when I mash the go pedal hard the engine misses and there is a popping sound.
My gas mileage has gone down 2-3 MPG.
Has anyone experienced this problem?
I can't afford to take the truck to a dealer to diagnose and hope I can fix it myself.
ANY help will be GREATLY appreciated!
Thanks, Phil
Thanks, Phil
are you throwing a cell when it does it? if so get the code read. you have 1 or 3 choices here.
60K....you might have a bad COP, you might have a bad plug, or you might have a faulty injector.
try to get it to do it and throw a code. moneys tight....been there done that. if it throws a code see which cylinder it is giving you the code. then switch COP's with another cylinder and see if the code will follow you or if it stays on the cylinder. if it follows you and moves to another cylinder then replace the COP. if it stays on the same cylinder that you originally got the code from, you either have a bad plug, or a bad injector. might be cheaper to replace the 1 plug until you come across some money in order to do them all. or do both. a Motorcraft plug is 8 bucks, and an injector ( cant remember but guessing its about 50 or so bucks from orielys )
hope this helps.
hope this helps.
Mine was doing the same thing and idling rough when cold.
After replacing the plugs, fuel filter and o2 sensors, the thing is running like new.
The plugs on mine were a royal PITA. Broke 5 out of 8, but that Lisle tool worked well. Make sure you insert the pusher pin (the instructions don't mention it) and you need a deep 15/16" socket for the outer nut on the tool.
andrewzx92000
12-09-2016 05:43 PM
Garryche
05-03-2011 10:22 PM
