Expected life of 7.3 vs 2011 6.7??
Old 02-26-2011, 10:02 AM
bigtexan99's Avatar
bigtexan99
bigtexan99 is offline
I was watching this slideshow on the Ford 6.7 diesel and the engineers were saying that they tested the engine to 250,000 miles.
Diesel Forum Presentation
Does anyone know what International tested the 7.3 to? I know there are alot on the road with 400k+ miles. Was the 7.3 a freak of nature or was it designed that way?
Old 02-26-2011, 10:20 AM
ty8573's Avatar
ty8573
ty8573 is offline
I will vote freak of nature.hahaha
Old 02-26-2011, 10:21 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
When we bought our 7.3 work trucks we scheduled them for engine overhaul at 300k miles because that was what the dealer said the life expectancy was.
Since then we have had 2 trucks run over 600k until we traded them in. At the time they were still running fine. For the remainder of our fleet, we adjusted the overhaul marker to 500k and will see what they look like when the time comes.
Not sure what the 6.7 published life is...I think it's still at 300k according to Ford. The Cummins 6.7 is 500k.
Old 02-26-2011, 10:23 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
The freak of nature is the EPA.
Old 02-26-2011, 10:36 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
I think rear axle ratio has something to do with engine life.
My F550 with 4.88 is on it's second engine, replaced at 105,000 miles.
It didn't blow up, but developed a knock that was audible on deceloration.
I didn't want to be stranded somewhere out on vacation with the 5th wheel so I elected to replace it.
Bfife's F550 is on it's second engine too. He bought it that way from the government and it was replaced somewhere in the 30,000 mile range according to the report when he bought it.
Old 02-26-2011, 12:48 PM
camodown's Avatar
camodown
camodown is offline
Per International's literature, the T444E has a B10 life of 200,000 miles and a B50 life of 350,000 miles, which is the same as the older 5.9 Cummins B series. With Ford's programming, I don't know, but can reason those aren't too far off from what I have seen.
Note: Cummins does not publish B10 for their ISB 5.9 directly, only B50
Last edited by camodown; 02-26-2011 at 06:36 PM. Reason: Confused my numbers B20/b10
Old 02-26-2011, 02:10 PM
PaulDH's Avatar
PaulDH
PaulDH is offline
Originally Posted by camodown
Per International's literature, the T444E has a B20 life of 250,000 miles and a B50 life of 500,000 miles, .
What's the definition of B20 and B50?
Old 02-26-2011, 02:15 PM
Quick444's Avatar
Quick444
Quick444 is offline
I think it is described as the "half life" of the engines. If I am correct, I think it means that 20% of the engines will require a major overhaul at 250,000 miles and 50% of them will need a major overhaul by 500,000 miles.
We will see what the pros think but I thought I read this somewhere before.
Old 02-26-2011, 06:34 PM
camodown's Avatar
camodown
camodown is offline
The definition of Bx life as per International is 'requiring major repair which requires head removal or oil pan removal.'
Old 02-26-2011, 06:47 PM
PaulDH's Avatar
PaulDH
PaulDH is offline
Does B20 mean that International projected that 20% of their T444Es were likely to require major repair by 250,000 miles? And does B50 mean that 50% were projected to require a major repair by 500,000 miles?
Old 02-26-2011, 07:45 PM
camodown's Avatar
camodown
camodown is offline
Yes, major as in one or both heads off, or oil pan coming off. I misquoted the B50 as 500,000 mi whereas it really is 350,000. This is ONLY an estimate though!
Old 02-26-2011, 11:14 PM
4wydnr's Avatar
4wydnr
4wydnr is offline
If the oil pan coming off is a marker for the B10 or50, then the mileage would have to he way lower than 300k. Simply due to oil pan rust.
My 7.3 made it just shy of 170k. It's a good thing I have a cummins with 300k to get me around, or I'd be pedaling a huffy.
Old 02-26-2011, 11:24 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
x2
i think the reason it last is it is simple KISS. all the new ones have 100 sensors more to go bad.
Old 02-26-2011, 11:29 PM
dn29626's Avatar
dn29626
dn29626 is offline
I would like clarification too.
Old 02-26-2011, 11:33 PM
ricksw's Avatar
ricksw
ricksw is offline
Whats for say ford the 6.0L for life
Quick Reply: Expected life of 7.3 vs 2011 6.7??
