Towing Capacity
Old 02-24-2011, 12:39 PM
SouthernHiker's Avatar
SouthernHiker
SouthernHiker is offline
Towing Capacity
Could anyone help me determine the towing capacity for my 1985 Ford F150 XL, 302 V8.
I'm weighing whether to sell this one and buy something newer to haul my camper, or pouring some money into getting this one fixed up. Everything runs great on it.
Thanks for any help.
Old 02-24-2011, 01:49 PM
bashby's Avatar
bashby
bashby is offline
what trans do you have?
Old 02-24-2011, 01:52 PM
f100jim's Avatar
f100jim
f100jim is offline
Towing capacity will depend on what trans you have, what rear end ratio you have, and tire size.
However, the real limiting factor is going to be STOPPING the trailer, not pulling it. The F150 does not have monster brakes, so even if you had a 460 with 4:88 gears, you would not want to pull a really heavy trailer. Personally, I would not want to pull anything over about 4000 lbs with F150 brakes.
Old 02-24-2011, 01:53 PM
SouthernHiker
I know it's an automatic, is there more you need to know?
If so, where can I find it? Sorry, I'm an idiot when it comes to vehicle mechanics.
Old 02-24-2011, 01:56 PM
SouthernHiker
Trailer Brakes?
If I installed trailer brakes, think it would still be problematic?
Old 02-24-2011, 01:59 PM
86sixbanger's Avatar
86sixbanger
86sixbanger is offline
Trailer brake controller????
Your trans is either a c6 or aod. Do you have an "OD" position on your column gear selector????
Old 02-24-2011, 02:03 PM
bashby's Avatar
bashby
bashby is offline
Does it have OD? Your shift indicator will tell. trailer brakes definitely help. The AOD trans isnt very strong without mods, but I dont know for sure how they will hold up towing. Someone else might be able to advise more. If you want to know gear ratio there should be a sticker on the door jamb with a code (one for the trans also). Post your code, someone will decode it.
SouthernHiker
Yes there is an OD.
Old 02-24-2011, 02:05 PM
SouthernHiker
Thanks, but the sticker has long worn away. It is an AOD, and I would plan on a brake controller.
What kind of mods are we talking about, and any idea on costs of getting something like that done?
Old 02-24-2011, 02:23 PM
Redneck1465's Avatar
Redneck1465
Redneck1465 is offline
Better question is what kind of camper are we talking about? How big is she?
Old 02-24-2011, 02:29 PM
SouthernHiker
Haven't purchased yet, figure i need to decide on the truck first.
I'm guessing around 25-28 feet...ideally a "lite" so I'm hoping between 4000=6000 lbs. or less
Old 02-24-2011, 03:57 PM
86sixbanger
doable but it wouldn't be very fast, even with a gear swap. You will probably have either 3.08's or 3.55's. 4.10's would be ideal.
Old 02-24-2011, 04:28 PM
Redneck1465
Personnally I would try and figure the camper out that you want then decide if the truck was big enough to handle the camper you want. I would think it could do that size camper if you have trailer brakes and such. Like previously stated it wont be fast but it should get the job done.
Old 02-24-2011, 05:32 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,683 Likes on 1,359 Posts
That 302 is awfully small.
Old 02-24-2011, 05:42 PM
86sixbanger
thats not what she said.....
Quick Reply: Towing Capacity
