Bad Injector O Rings cause blow by and oil consumption?
#31
while you are correct that there is no "return" per se` from the fuel galleys to the fuel bowl... a high pressure oil leak can and will push past the 70max psi fuel pressure with all of its 3000psi might during a wot scoot down the road.
pay heed to what Brother Rich said about your compression numbers...
start looking for another motor... that one is on borrowed time with even 1 cylinder reading 200psi.
if you can stand for it to be down pull it NOW and get it into a machine shop.
since there still is some compression there is a good chance it can be salvaged...
even if it means sleeving cylinders..
#32
Autoenginuity. I've had a few different readers and this one seems amazing
The autoenginuity tool seems to be the best. With the OE Ford upgrade I can buzz test and do a contribution test. All sorts of stuff. I'm going to make a YouTube video about my Innova vs. my autoenginuity scan tools. Major difference but original purchase price was the same. The upgrade was another 200 but worth every penny.
PSDLOVER
05-02-2009 07:35 PM
mstepchinski
16
07-12-2004 02:25 PM
d0n_3d
1983 - 2012 Ranger & B-Series
12-07-2003 09:01 AM
