Cryo brake rotor problems - now what?
I installed Centric cryo treated slotted front brake rotors on my '01 F-250 SD CC. I also installed OEM Ford pads. They worked well for about 38k miles.
Now the front wheels have a bad braking shudder at speeds above 45 mph.
Has anyone else had issues with cryo treated rotors?
I am also wondering if it is worth resurfacing the cryo rotors? or is it best to get new rotors?
I'm surprised your cyro treated rotors have warped. That's the last thing I'd expect. I'd have a runout performed on the rotors before going any further. You could have something else going on. As far as resurfacing I think you have two issues, one is the fact that the rotors are (or should be) extremely hard due to the cryo treatment and the other is they are slotted. I think both will cause issues for the equipment used to turn them.
I put ART cryo slotted front rotors on my truck 3 months. My thought going into the upgrade was that if I ever had a problem with one or both rotors, I'd replace them.
The rotors are not warped. There is 0.001" runout on one side and 0.002" runout on the other side.
However, there is bad shudder coming from the brakes when applied about 45 mph.
Since there is little runout, I suspect, but can not verify, that the rotor surfaces have variable hardness causing the shudder.
I am now wondering if the cryo rotors are not that big of a benefit over quality non-cryo rotors.
There is a school of thought that the feeling of warped rotors in this case can be attributed to pad material being deposited on the rotor surface (causing differing friction around the rotor). You might consider going over each rotor surface with a steel wire wheel brush on a drill and seeing how this affects the problem. I frequently scuff rotors when replacing pads to remove the shine, if I'm not otherwise turning or replacing the rotors.
Check this out:
StopTech : Balanced Brake Upgrades
