Coolant Leak Pt.2
Coolant Leak Pt.2
Hey Guys.
Well i had coolant leaking from my truck about 2 weeks ago and found out the water pump was bad. So i replaced the water pump,t-stat, and t-stat housing. Did this about a week ago and everything has been fine.
Now i started my truck up yesterday morning and it was leaking coolant like crazy. I got under the truck and couldn't see where it was leaking from. Its not leaking from the water pump or the radiator, its dripping off the starter.
Could this be a freeze plug?
This is my work truck, local shop is jammed until thursday so for now im stuck... Thanks for any help.
-Matt
-Matt
Probably not! Hard Starts are usually caused by the Glow Plug System, batteries, starter, or oil issues.
Take a look at the cold start thread for more info: https://www.ford-trucks.com/forums/1...ky-thread.html
