You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Pics of the carnage from a failed timing chain in a 95 5.0L F150
Three weeks ago, I was cruising down the highway at 75-80 MPH (about 2200 rpm) on my way to work when all heck broke loose under the hood of my F150. I just finished the engine swap in it a few days ago, so I thought I'd tear down the old engine to see what had failed. Here are the pics.
While unbolting the oil pan, I could hear pieces falling/moving around. Here is a pic of what I found in the sump of the pan.
The crankshaft sheared just in front of the second main, then proceded to overlap itself. Check out the bent rods.
I hadn't touched the bolts on the front main yet...look at the gap between the main cap and the block. Also, note the timing cover damage.
As soon as I started to remove the front main, the front of the block disintegrated. Cylinders #1 and #5 are both cracked as well.
Here's my newest trophy for the wall of carnage in my garage. I pointed out a few "issues" in this pic.
My conclusion is that the timing chain failed and wrapped itself around the crank gear, effectively locking the front of the crankshaft. When that happened, the engine went catastrophic. I was just amazed at the damage and thought some of you guys might get a kick out of seeing these pics.
I was planning on building a 351W-based engine for it this summer when I could handle being without the truck for awhile, but since this happened at the worst possible time of the year, I threw another 5.0L in it for the sake of keeping it quick and simple. I deleted the smog pump and its associated plumbing while it was out, and I'll have a new stainless Magnaflow exhaust on it shortly, but that is pretty much the extent of the upgrades.
I may still build an engine for it this summer, but we shall see.
The 5.8 would have been a simple plug and play... FYI... It's pretty much the same as the 5.0 just is wider. You can use same engine mounts and all. You would have needed a new flexplate if it was an auto but that's about it as far as modification... 5.8's are plug and play!
__________________
Thumper 88 F250 ZF 4x4 4.9L 3G 238K-main work horse
Zeus 89 F250 ZF 4x4 351w 143K- tow rig project
Ol' Girl 83 F150 NP208 300 T18 358K Offy DP 4bbl Holley Did I say somthing GOOD? Click MY HEART!
Nathan - FTE Iowa Chapter
WOW!! I think my 95 jumped a tooth on the timing chain,but it didn't do damage,it will start as I found out a few mins ago when I advance the timing quite a bit. As far as a 5.8 being plug and play yes it is if your 95 is a MAF truck like mine.
__________________ I'LL KEEP MY GOD,MY GUNS MY FREEDOM AND MY MONEY YOU KEEP "THE CHANGE"!!
1995 f150 xlt extended cab flareside 5.0 33" tires 3" body lift
That actually ain't the first time I see this happen on a 5.0L....
Ouch though!
__________________
1990 Ford F250 4x4, ZF5, L/S 4.10, N/A 7.3L Diesel, 568,808km/377,497 miles, still on the original clutch!
1989 Ford F150 300-6, C6, 2.73, 127,000km/79,000 miles.
1987 Ford E350 26ft. Motorhome, N/A 6.9L Diesel, C6, 3.54, 265,000km/166,000 miles.
1985 Ford E350 Ext Van, 6.9L Diesel, C6, 4.11, 658,000km/411k miles
The thing was, I had another complete '95 5.0L readily available, versus having to track down a 5.8L.
The engine had just over 209,XXX on it. The timing chain was replaced around 150,XXX miles, but that engine had seen its share of revs and abuse. As far as warning signs, all was well right up until the second it let go.
__________________
Are there any fatigue marks on the crankshaft split line? It's hard for me to imagine a broken timing chain causing all this mess (I deal with engine failures at work). Have you gotten a look at the top-end/valvetrain yet?
