Hi
I have a fellow here wanting to buy my 96 psd auto.He has a 92 auto.Will his trans work in my truck? My tranny is done but he has a newly built one in his 92 and his motor went.
Thanks
Jake
If both trucks had the same engine, then you're close. The '92 diesel torque converter had 4 studs, the '96 had 6. You might be able to change the flex plate, but the better way is to get a new 6 stud torque converter.
The owners truck is a 92 with the old 7.3 but mine has the powerstoke.Just wondering about the electrics or is his would also have solenoid valve body etc.
