I have the 3 bulb light bar that goes under the tailgate on the duallies that I want to put on my 2011 F-350 SRW. There is a connector at the end of the pigtail on the light bar. Is there a connector under the truck this plugs directly into, or do I need to cut off the connector and splice into the trucks wiring?
i added them to my truck (11 years older than yours). there was no connector on my truck. i just found the running light wire on my trailer plug and spliced into it. very easy.
Because your truck is a SRW, you probably don't have the harness underneath. It doesn't hurt to look, but the DRW are the trucks that usually get that running light. When I added mine, I spliced right into the license plate light wires. It's a quick, and easy job. Good luck.
Thanks all for the replies. I had one on my previous truck which I just spliced into the wiring, but I was hoping this one had the harness down there.
Originally Posted by bcrispy
where did you get the light bar?
bcrispy - I got the light bar from www.southwestfordparts.com, however their website seems to be down right now or else I'd give you a link to the part. I wanna say it was around $44.
