New 6.4 Owner
Congrats also..I just bought a used 08 F450 with 33,000 miles but did the DPF and Cat removal and the SCTLivewire. Happy with my choice. Called the dealer first before removing the stuff and they said ONLY IF those removed items would or could be shown as reason for a failure did it make a NO. So I did it.
Have only had SCTL on for about a week so to sure on all the programing modes yet.
The Dealer is not being straight with you. Remove the CAt/DPF are instand void of factory warrentee. Re program the Computer again Mother Ford will nto pay for your work.
Save all the original stuff and be able to reistall before the trip tot eh dealer and you have a chance.
51,575 miles
Interesting turn of events... the leak started during a real cold snap and only after a short run 25-23 minutes. After that the leak disappeared....
Came back again and really could not figure out where it was coming from other than the left side. Added 1 can of stop leak and it has not resurfaced. .... One of the things to be replaced/upgraded is the radiator to an all aluminum unit from Davis. Intercooler will be done at the same time..
Cheers
Cheers
mbellerive
03-23-2011 09:12 PM
MattyNJ
6.4L Power Stroke Diesel
10-07-2010 08:53 PM
