48V vs 58V FICM
Old 02-12-2011, 01:00 PM
timbrady's Avatar
timbrady
timbrady is offline
48V vs 58V FICM
It appears that I have a bad FICM, based on the test procedure in the Tech Folder. So, now I'm looking at replacing it. What's the difference in the stock 48v version versus the 58v upgraded version, other than the obvious voltage difference. Do I gain reliability, performance or what? Likewise, is the change in programming worth the money? What do you see from that?
Thanks for the help!
Old 02-13-2011, 04:17 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
The 58V version supposedly helps with injector stiction and supposedly the higher voltage FICM's are a little higher HP. Reliability has always been a question, but Swamps claims that after more than a year of doing this upgrade they haven't seen any issues with FICM reliability. As far as reprogramming goes, the PHP reflash has been reported to give a little better MPG and better throttle response.
Old 02-13-2011, 08:05 AM
cheezit's Avatar
cheezit
cheezit is offline
Ive check out a few trucks that had the "58v" mod. they were closer to 53v
Old 02-13-2011, 09:47 AM
npccpartsman
Did you read them with a meter at the FICM or from IDS? I know that AE can't read over 52 on the FICM and wonder if IDS is the same.
Old 02-13-2011, 11:02 AM
timbrady's Avatar
timbrady
timbrady is offline
So, what I'm hearing is that there isn't a large difference in one versus the other? If that's the case, I might as well go with the cheaper version.
Old 02-13-2011, 01:41 PM
cheezit's Avatar
cheezit
cheezit is offline
with an ids.... I never thought about that being a cause.
Old 02-13-2011, 02:19 PM
BobsF350's Avatar
BobsF350
BobsF350 is offline
rockauto.com sells a FICM for 305.00 remans +core charge search rockauto discount code thats 5% off
Old 02-13-2011, 02:42 PM
mixerdrvr's Avatar
mixerdrvr
mixerdrvr is offline
What would the higher voltage do to the injectors???
Old 02-13-2011, 05:39 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
That's a good question I've never heard a good answer to. It seems like it'd be sorta like running a 12V light bulb on 20V. Maybe not all that good on the coils.
Old 02-13-2011, 05:47 PM
Dr. Beeker's Avatar
Dr. Beeker
Dr. Beeker is offline
That may be true, but think of it this way. A light bulb is on continuously, where the injector is turning on and off 325 time a second at idle. the more voltage the more confident you are of a positve on and off cycle. I think the more volage the better is true, less missfires.
Old 02-13-2011, 05:51 PM
dchamberlain
Regardless of how often it is on or off, you are still putting more voltage through the coils than they are designed for. When working properly, they don't misfire at 48V, so why would I want to put 58V through them?
Old 02-13-2011, 06:14 PM
amadas350's Avatar
amadas350
amadas350 is offline
more electricity = larger magnetic field around coils.. so it should have a little bit more force to open then, and help stiction.
now about added hp, dont know if that really happens.
Old 02-13-2011, 07:01 PM
69cj's Avatar
69cj
69cj is offline
Insulation is rated in resistance to ground based on voltage. Is there any proof that the increase in voltage does not hasten the break down of the insulation?
Old 02-13-2011, 07:37 PM
ljutic ss's Avatar
ljutic ss
ljutic ss is offline
I think the math comes out to 5.4 injector cycles per second, or 325 times per minute based on 650 rpm.
Old 02-13-2011, 07:41 PM
ljutic ss's Avatar
ljutic ss
So if 58 volts is better then 48 volts, then why isn't 70 volts better then both? JMO 58 volts is a sales gimmick.
Quick Reply: 48V vs 58V FICM
