Need help
How often is the truck going to be used. If seldom, I would use grease and the axle seals if you have a choice. If you are going to use the truck everyday, as stated above use oil seals on the hub and leave out the axle seals. The oil will migrate back and forth down the axles to lube the bearings. If you haven't removed the hubs yet, I think you will find that it is probably this way(fairly recent axle) it already is. If you do decide to go the oil bath route, it won't hurt a thing to lightly pack the bearings with a little grease also.
If the rear has any kind of limited slip/locker in it do not use synthetic oil in it. You will destroy the clutches(Too Slick for heavy duty applications).
There is a reason that tractor trailers run all oil bath hubs. The bearings stay cooler and last longer.
rpenterics
06-20-2012 11:43 PM
aircraftfixer
21
01-24-2007 08:06 PM
jambroson
03-01-2004 10:47 PM
