6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Help! My truck is using water??
Old 02-11-2011, 05:02 AM
Hdfunone's Avatar
Hdfunone
Hdfunone is offline
My truck was low on water, so I put some in. Next day was low again. Took it to the dealer and they put a new hose on it. Didn't like that because no water on the ground. So I took off on my trip to Key West. Notice the eat gauge going up so I stopped. Water low again, put more in. Had to do that every 100 miles. Called the dealership and they haven't called me back yet. Anyone had any problems like this? Thanks Derek....51,000 miles
Old 02-11-2011, 05:06 AM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
you are probably needing EGR coolers or the EGR valve is seeping coolant. I take it that we are talking 6.4 here right?
Running low like that is very dangerous and leads to cavitation. Any white smoke while driving? How are your regens.
Have you looked at your tail pipes? Wet, clean, black?
Old 02-11-2011, 07:14 PM
kane gray's Avatar
kane gray
kane gray is offline
CHECK YOUR OIL!!!!! You could have a bunch of coolant in there due to front cover cavitation.
Old 02-12-2011, 07:20 AM
Hdfunone's Avatar
Hdfunone
Hdfunone is offline
Yes 6.4
Thanks for your reply.....seems to be cleaning the exhaust alot. Runs great as also. The tail pipe is not different...black and dry. I have Banks on it, so I can read the temp. Just stop when it get over 212 and put a gallon in it. You helped me when my truck was new and over heating. They put a radiator in it but that didn't help, then new radiator caps, then they found the real problem...the thermos were broke. My truck is a Job 3,,,love it but think I am going to order a 2012. Going to the dealer up in Daytona if I can make it..lol
Old 02-12-2011, 07:26 AM
senix's Avatar
senix
senix is offline
my guess then is because of the orginal problems I would almost be there was some caviatation and now that is where the coolant is going. Problem is the only way to check is to pull the water pump.
That is the most likely place for the leak.
They can pressure test the coolant system on the truck before any work is performed.
How is your oil level?
Old 02-12-2011, 09:36 AM
Hdfunone's Avatar
Hdfunone
Hdfunone is offline
Oil ok
Oil is ok...no water, but I forgot to tell you the truck is making a siren sound under power?????
Old 02-14-2011, 09:58 AM
USMA06's Avatar
USMA06
USMA06 is offline
What is cavitation?
Old 02-14-2011, 11:02 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
Originally Posted by USMA06
What is cavitation?
running a pump dry
Sam
Old 02-14-2011, 02:55 PM
Hdfunone's Avatar
Hdfunone
Hdfunone is offline
Blew up!!!
Leaving Key West headed to Daytona for the race.....boost went to 0 and motor quit. Tow truck just towed it to a Ford dealer and we are sitting in a church parking lot in the toy hauler drinking beer. Will post what the dealer says later. My Chevy left me dead along the road dead also. Fun Fun...
Old 02-14-2011, 03:35 PM
senix's Avatar
senix
senix is offline
tough luck...my guess is some of the above got you.
Old 02-15-2011, 08:29 AM
Hdfunone's Avatar
Hdfunone
Hdfunone is offline
Bull sh__
Dealer just called and said it was a bad senor and they would fix it for $777.00. I told them OK if they can tell me why the senor would cause the truck to use water. I have put over ten gallons of water in it in two days. They said they will call me back.........
Old 02-15-2011, 09:14 AM
senix's Avatar
senix
senix is offline
So maybe one of the EGT sensors shut it down...but does not explain the water as you said.
Old 02-15-2011, 10:04 AM
Hdfunone's Avatar
Hdfunone
Hdfunone is offline
More problems
Dealer just called again...oil cooler is blown.....taking cab off...I asked where the water is going....he says he doesn't know yet.....but he is going to check the EGR.....just what ou told me weeks ago...lol. They will have the truck for over a week. Great vacation...maybe Ford will give me a loaner...another laugh.....What do you think of the 6.7s? Thanks again for all your help..
Old 02-15-2011, 11:04 AM
senix's Avatar
senix
senix is offline
I would wait just a bit longer on the 6.7 myself.
Sign up for Good Sam RV road service. Great program for us that travel with TT or 5er's.
Old 02-15-2011, 06:57 PM
Hdfunone's Avatar
Hdfunone
Hdfunone is offline
2012??
Yes, waiting for the 2012....what do you think? Is the oil cooler warr.?? and why do they had to take the body off for that???
Quick Reply: Help! My truck is using water??
