New 1996 f150 4.9L 5 speed questions
Old 02-09-2011, 08:52 PM
2002exPSD's Avatar
2002exPSD
2002exPSD is offline
Well I just purchased another truck. This truck is so clean it looks new off the line. Garaged since new and always maintained.
What kind of weight can I tow with it. Bumper pull and 5th wheel. Any modifications for more power? Mpg?
Thanks
Old 02-10-2011, 05:49 PM
2002exPSD's Avatar
2002exPSD
Bump ttt bump
Old 02-10-2011, 05:58 PM
octaneforce's Avatar
octaneforce
octaneforce is offline
do a search, theres so much information about this. what gear ratio is your rear end? check out the ford 300 forum to see what kinds of mods are done to these motors. without tearing the motor apart, you should probably just do a good tune up and slap on a turbo muffler. tune up would include cap, rotor, plugs, wires, air filter, fuel filter, etc. aka the "6 litre" tune up. if you dont already know about the 300, youll learn that its a great pulling motor with lots of low end torque. im really not sure what your truck can pull, but my boat is a little over 3000 pounds and i hook to my bumper all the time without a problem. (truck in sig)
Old 02-10-2011, 06:08 PM
2002exPSD's Avatar
2002exPSD
I tried doing a search,but when I type in a keyword and select the forum/category i want it searches all forums anyway. I haven't picked up the truck yet, but have paid for it already. Flying to Louisiana tomorrow to pick it up and drive it back to Texas. Don't know the axle ratio yet. Hoping it's 3.55 or 3.73 and not the 2.55's or 3.08's.
Old 02-10-2011, 06:11 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
Where are you at in Texas?
Old 02-10-2011, 06:14 PM
octaneforce
these motors seem to like 3.55 gearing. however i have 2.73's in my truck and it seems to chug right along with any amount of weight i put in it, and i can cruise at 70 and still get decent mpgs. 3.55 or 3.73 would be good if your hauling loads around town. good luck with that trip. you must really trust the truck!
Old 02-10-2011, 06:29 PM
rquinlans's Avatar
rquinlans
rquinlans is offline
I have one and tow a two horse trailer pretty regular in the summer at slower speeds , 55 mph , with a heavy duty receiver hitch and it does fine. The problem with these trucks is not the engine but the wimpy *** clutches. Be very careful when backing a load , seems thats the best time to smoke a clutch. Wish the reverse was a granny gear.
Old 02-10-2011, 06:35 PM
2002exPSD's Avatar
2002exPSD
I'm in spring texass
Old 02-10-2011, 06:40 PM
2002exPSD's Avatar
2002exPSD
Every ford ive ever owned has been bullet proof. I trust my favorite and best quality truck. FORD!
Owned fords:
2004 ford excursion 6.0
2002 ford excursion 7.3
2007 ford f250 6.0
1996 ford ranger 2.3
1997 ford ranger 2.3
1989 Lincoln town car 5.0
Old 02-10-2011, 08:50 PM
fordman1090's Avatar
fordman1090
fordman1090 is offline
The 300/5-speed combo is unstoppable. The 300 is a workhorse and will pull hard all day long, day after day. The mazda 5-speed will be the weak link, but mine lasted 150k of HARD towing before it died.
As for weight, iv towed 10k+ behind my 300/zf5 combo with a 3.55 rear end and 33in tires, giving me an actual ratio of 3.08. add the total weight of my truck, 6k giving me a grand total of about 16k. And i didnt have any problem keeping up with traffic. However, you will have to give it a little time to get up to speed.
and, i would not suggest towing that much weight behind a normal f150, but its nice to know that 5k or so is nothing for that beast.
Old 02-10-2011, 08:56 PM
octaneforce
how did you stop that much weight with a 150?
Old 02-10-2011, 09:01 PM
2002exPSD's Avatar
2002exPSD
Well that's good to know. I really want to get a nice 5th wheel of at least 23 feet. I like towing at 60-65 mph. From all that ive heard about this motor, it sounds like it can pull as much weight as my excursion 7.3 diesel. Rated at 12,500 lbs. Currently I have light trailers. 3500 lb boat and 7 jet skis.
Old 02-10-2011, 09:17 PM
fordman1090
You biggest enemy is going to be the large profile of a travel trailer. However, i have towed some really big high profile loads that sat on a tall flat bed, and i never had a problem holding 70, and even passing on the hills.
I think the biggest thing that turn people away from the 300 is that it really takes a long time to get up to speed. But if you give it some time it will pull anything. They are great little engines.
Old 02-10-2011, 09:20 PM
fordman1090
Good question, not to long ago, i wouldnt have been able to stop it, but after a close call i really beefed up the brakes. 1 ton brakes front and rear, as well as hydro-boost. It stopped 16k on a dime
Old 02-10-2011, 09:28 PM
octaneforce
any chance you could share the specifics on what kind of brakes you bought? you found 5 lug one ton brake rotors? also, what is hydro boost?
Quick Reply: New 1996 f150 4.9L 5 speed questions
