Front sway bar and lift? Pictures. Help!
Hey guys, I just finished installing a 4" lift on my 1996 F-250 and when I went to reinstall the front sway bar it now hits the springs. I dont understand what is going on? The sway bar I have attaches to the front of the truck right behind the bumper and from what I can tell.....there is no way it is going to go back on. Let me know if any of you have had this problem or if there are any ideas to make it work. I was wondering if Ford offered 2 different sway bars because mine looks different than the one in the pictures in the instructions for the end links. Thanks, Mike
image upload
image uploading
hosting images
hosting images
image hosting
hosting images
free image upload
image upload
image uploading
hosting images
hosting images
image hosting
hosting images
free image upload
I already have longer sway bar links. I got them with the kit. Thats not the problem. The new spring is right where the sway bar use to run because it has so much more arch and more springs in the pack......so when I hold it up you can see it is going to be either waaaaaay to high or waaaaay to low. It cant sit where it needs to sit.
I got the Rough Country 4" kit. I dont know if the drop down blocks will work or not. I will look into it. Does this sway bar set up look like the rest of you guys that have a front sway bar? Its not an aftermarket sway bar is it? I may end up not using it but wanted to if I could. Would it be a bad idea to not use the front but keep the back sway bar? Just have the back sway bar hooked up? Thanks, Mike
The general consensus seemed to be that you don't need a front sway bar. These new springs are much stiffer and most of the body roll in a turn is in the rear. (the front is initiating it, the rear falls victim to it) As long as you run one in the rear, which I don't, you really shouldn't notice any difference. I have no sway bars and it handles just fine. Like 96f350az said, they're lifted trucks, not road rally cars.
rangermike
101
10-28-2012 08:39 PM
OldStyle
01-07-2012 07:28 PM
Jamerian
11-09-2011 06:23 PM
