Fuel Filter Light then shut down
Hi
Just got this Powerstroke together and has been running great. I have a fuel issue that has been leaving me stranded, particularily on cold mornings. First, I had a major fuel leak so I replaced the mech fuel pump and all the blue and black fuel lines. I still have a much smaller leak but the vally is still filled with fuel. I have a suspicion its from the fpr. Almost ever since, the water in fuel light is always on. This is the issue: On mostly cold mornings, I will be driving after a good warm up and the fuel filter light will flicker and then come on. Shortly after I would hear a fluid type of sound and the truck becomes weaker until it stalls and shuts down. It wont start after but parking it for a few hours, it would start like it never happened. Suggestians??
the 'fuel filter restriction sensor' look here, first post first picture, located on the side of the driver side fuel bowl.
https://www.ford-trucks.com/forums/1...ml#post9936363
Ford E8TZ-9S283-A
International 1809435c1
Much cheaper at IH
The senor will control the light coming on, BUT if your truck is dying, I would tend to think you have other issues than a bad sensor
Ford E8TZ-9S283-A
Much cheaper at IH
If it's happening with the rear tank only (meaning this happens with only one tank and not both tanks), it's possible there's some particulate flopping around in the fuel that's getting sucked up against and blocking the fuel pickup line.
You might want to run that tank as empty as you can get it, drop it and clean it out to see if anything is in there.
Another thought ocurred to me. If the leak is coming from above the fuel restriction sensor area, it might be the o-ring between the FPR and the fuel bowl is pinched or torn. Have you replaced that o-ring? If fuel is leaking from there, you may not be able to obtain the proper fuel pressure required. That might be why the engine is shutting off and the fuel bowl is full.
Kenzie
03-23-2016 03:38 PM
jsikora
48
04-27-2015 07:17 AM
v8motorcycleman
10-17-2011 02:31 PM
