1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
busted transfer cases!!!!
Old 02-13-2011, 08:31 PM
flamebuster's Avatar
flamebuster
flamebuster is offline
Wow, there is definately a big difference, the fins are even much taller and don't taper off..Saving money can cost you in the end just by reputation..New Process always had a good reputation. Thanks for sharing the photos.
  #32
Old 02-13-2011, 09:01 PM
Tom's Avatar
Tom
Tom is online now
Originally Posted by BrockwayMT
Well first off it cost hundreds of jobs in Syracuse, NY for the transfercase issue. Thus I refuse to get one. And I'm sure there's a couple hundred Navistar employees in Indianapolis who feel just as excited about the 6.7
But nevermind the guy who spent 3 years as a transfercase engineer knows nothing about them. There are legitimate concerns with Magna's Saltillo assembly operations. And as I said the castings are a lot lighter which makes porosity more dangerous.
The mention of a propshaft issue sounds most likely in my mind. It's happened before. I doubt it's torque related. Even if you did get the wheels hopping you'd most likely jump the chain at worst. You can get the chain jammed between the sprocket and the case and blow the chain out but it's not easy. I've seen it on the t case dyno but never heard of that failure in the vehicle.
But what do I care. The opinion of somebody who knows trucks means nothing. All you need to know is that what's newest and has 3 more hp than competitor X must be the best.
Here's the 2011 tcase. MP1528. Note this one was built in Syracuse because it has the red NPG tag. Most 271/273 in production in 2009 and 2010 had the red tag turned around backwards. For some reason Ford doesn't want supplier ID on the tcase, just the Ford logo. As you can see the transfercase forms the rear of the 6R eliminating the adapter housing.
Great info, thanks for posting this.
Interesting pics, I get what you're saying about the lighter casting and less ribbing, I wonder why they did that. Is it an aluminum casing? I wonder how much weight they saved on this...
  #33
Old 02-13-2011, 09:17 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
First off, let's leave the personalities at the curb
Second, GREAT info, GREAT discussion. Let's keep this going.
  #34
Old 02-14-2011, 06:04 AM
BrockwayMT's Avatar
BrockwayMT
BrockwayMT is offline
post deleted
BORDERBUM
04-10-2016 02:36 PM
Howie Carver
02-27-2016 09:38 PM
Howie Carver
02-27-2016 09:36 PM
IDI guy
12-25-2011 07:07 PM
BVA
08-26-2009 11:29 PM
Quick Reply: busted transfer cases!!!!
