2008 heated seats not working
No Warrenty
Sorry to here your out of warrenty.. I do enjoy the heat on cold days.
The paint on your string wheel????
My is a 09 with less then 12 k on it. What engine do you have? I had a hell of time with ford on my 6.0 diesel.
If it is the heating coil you should be able to replace it yourself. Check to see if are getting power when you push the button.
search for thread in excursion forum. there is an excellent one on heated seat fixes. I dont know if post 07 is wired the same but there are wiring diagrams in that thread. Just fixed my 01's was a broken wire in back rest pad.... resoldered put seat skin back on and voila! my butt is smoldering again...
if there is a broken wire in either the backrest or the seat part it will cause the seat in question driver or passenger to stop working. not both seats.... but could be broken wires in both as was in my 04.... and ford wouldnt fix them under warranty then... even with 38000 miles on the truck
mhopton
10-09-2013 05:53 AM
