92 F-150, duel tank fuel system
I have a 92 f-150 extended cab 4x4 with duel tanks, the truck quit running on the front tank so i switched to the rear tank. The truck will run on the rear tank, but it is pumping the gas from the rear tank to the front tank. Can anyone tell me if this is a pump problem or a valve problem? Any help i can get would be great. Thanks
It will require replacement of front tank pump assy, the valves are built in. After you fix this you may have the poblem I have I described here https://www.ford-trucks.com/forums/1...ed-issues.html
Thanks for the help. I have talked to 2 dealerships that said there was a frame mounted switching unit but i could not find it, had a buddy that used to work for a ford dealer look at it and could not find it. I'm going to replace the front pump. Thanks again for the info.
f150rd
08-08-2019 11:36 PM
oreodog
02-17-2012 03:42 PM
JasonDaniel
10-04-2011 04:14 PM
