BAD BAD FRAME BEND IN NOSE 86 F-150
on
You must keep the factory bumper in place when using a plow, or add a piece to tie the two frame rails together if the front bumper is not used. You would be surprised at the strength you lose by taking the bumper off.
I also made a support brace to go from the bottom of the plow up to a bracket that is bolted to the frame where the frame starts being boxed, near the steering box on one side, and the same general area on the pass side.
My mount is custom made, and I have had to re-enforce it and had design changes several times to make it strong enough, is why I asked about your mount.
on
I had a home-made mount on mine when I got it, when it bent the PO scabbed in another brace, then that bent and they added more bracing but the whole thing was not designed right from the beginning. I got lucky and scored the proper mount with a good pump from craigslist for $100!! There is no way your truck frame should bend from hitting a snow bank, unless you rammed a solid pile of snow at some crazy speed, the A frame of the plow is designed to be a "fuse" that will bend if you hit something, saving the truck frame.
