Putting it into 4x4
Start using neutral when shifting into 4Lo. The trans will spin freely to allow the transfer case gears to roll into Lo range much easier than when your trans is locked by the parking pawl. This is especially true on the older gear drive transfer cases. I've actually found that its usually easier to shift in & out of 4lo when you've got the vehicle just barely moving. It gets the gears to moving, and once they've started turning, its easier to get them to mesh than when they're sitting still.
As long as the front hubs are locked, you can shift from 2wd to 4hi at any time or speed. Just make sure you dont do it while the rear tires are slipping on snow or ice and the front tires are sitting still, as it will grind then go bang.
With a manual shift case, there is nothing to keep you from shifting it into any position at any speed. With my truck i can actually leave the manual tranny in gear while moving and shift from 4lo to 4hi by placing the t-case in nuetral and matching the rpms of the engine/trans to the t-case before returning the tcase to 4hi. It takes alot of practice and i do not recommend it. If you mess it up, you will likely break something.
My recommended shift sequence for 4hi to 4lo is to roll slowly with the transmission in N and smoothly shift from 4hi to 4lo without stopping at N on the t-case. Although i almost never have any issue when shifting from 4hi to 4lo or back while sitting still either.
12-03-2011 10:56 AM
SuperBerry111
08-17-2011 06:54 PM
zerfetzen
10-24-2010 11:51 AM
RollinroundMT
4 Cylinder Engines
04-03-2005 10:07 PM
