49 truck with 4.6 modular motor-IT'S ALIVE!!!
#62
#63
Coyote! Man that's gonna be sick! This truck has a 79-81 Camaro front clip. I took the frame mounts from the Mark VIII and welded to the Camaro clip. The engine was a little tight in spots, but no big problems. I used exhaust manifolds from and '03 Cobra which fit really nice.
Here's some pics.
Engine with truck 390
Donor car
Engine puller
Mark VIII mounts welded to Camaro clip
Cobra exhaust manifolds
Here's some pics.
Donor car
Engine puller
#64
#65
#66
This is a great build thread! I like it! Keep 'em commin!
I can relate with you on the time spent workin on everyone elses' stuff. Just as I get started on on of mine, i take in a side job and it get pushed out. The '56 stared as a side job for my pops but that changed and it's my project now so I decided to sideline the side jobs and finally try to get at least ONE done enough to enjoy for once! Hard to turn down the extra work though, since its a big contributor to my hobby!
#67
Thanks guys! I know what ya mean about turning down jobs. I've got an offer to paint a really clean car right now. It would be pretty decent money, and I'm already thinking about what I could be buying for my truck with that money. But I'm feeling really motivated right now and starting next week they are forecasting high temps here in the 70's. Perfect weather to get the frame outside and start blasting.
#68
More fun work! The previous owner had a 79-81 Camaro front clip welded onto the frame and the front sits higher than I want. Don't want the expense of bags right now so I "Z'd" the frame. ( I guess that's what you could call it). Anyway I dropped it 4" so hopefully that will get it closer to the look I want.
#70
I'm using the stock transmission mount. I had to drill new holes.
I have the Mark VIII frame mounts welded in already. I still need to box them in on the back side.
Made a radiator support.
Still haven't decided if I'll go with bumpers or not.
#71
I don't want to be a buzz kill but, I am curious and so I will ask:
Will that compensate for the 4" elevation change from the frame to the front crossmember?
Will that lower the engine 4" in the front crossmember or raise the trans 4" or are you splitting the difference and moving each 2"?
Have you dropped the front frame horns 4" also to accomodate the front fender mounts and radiator support?
#72
Will that compensate for the 4" elevation change from the frame to the front crossmember? Not sure what you mean here.
Will that lower the engine 4" in the front crossmember or raise the trans 4" or are you splitting the difference and moving each 2"? It won't affect the engine. I needed to lower the transmission tailshaft some anyway. I'll just fab maybe a 2" filler piece on top of trans crossmember.
Have you dropped the front frame horns 4" also to accomodate the front fender mounts and radiator support? No. I have a fiberglass tilt front end. All I have to do is mount the hinge point lower. My basic areas of conern were hood hitting radiator after lowered (I believe I had well over 4" of clearance there), transmssion maybe into the firewall some now (just cut some more .
#73
Was curious if drilling new holes in the trans mount and where you have the motor mounts welded in would accomodate the 4" difference between the two frame sections if the engine sat level before you modified the frame. Probably moot at this point. The next answer clarified things a bit.
A flip front end changes everything. Sounds like you've done your homework. I must have missed the part about the flip front end earlier. Nice looking welds you have there. I wish mine looked like that.
#74
#75
