99 f-450 ring and pinion change
Old 12-07-2016, 04:24 PM
SteamedKeck's Avatar
SteamedKeck
SteamedKeck is offline
F-450 Gear change
Just wanted to wake up this thread to see if anyone has any new thoughts/Experience on changing gears vs. Gear Vendors OD... I am interested in the Detroit locker 3.90's but the 4.30's would be fine in my application. The 4.88's just aren't practical unless you're trying to pull the devil out of hell...
Old 12-09-2016, 11:30 AM
Dirtscooter250's Avatar
Dirtscooter250
Dirtscooter250 is offline
I had an F550 with gear vendors and it did not make a big difference in fuel mileage. I got 11 mpg instead of 10 and it does not shift smooth if you have an auto unless you anticipate and match engine speed. If you shift under full throttle it will bang so hard everything shakes in the cab same thing if you downshift. Also have a gear vendors on an F350 with 4.10s and fuel mileage was barely any different. The only benefit was the in cab noise was less. The lube capacity was tiny and there was no extra cooler for it so towing heavy in OD is a no.
If you are looking to regear an F550, the 4.88 carrier needs to be replaced with the next lower carrier since the carrier that works with the 4.88 R&P does not work with a 3.73. These are hard to find by the way.
If you are looking to regear an F450 and it has the Dana 80 (Ford did not add the S14-110 to the F450 until later 2003 as far as I am aware), these are not a drop out design like the S135 or S14-110 rather they can be serviced through the rear diff cover and changed gearing like a regular light duty rear end. Gearing changes are less involved since the ring gear is not riveted to the carrier.
King-bRanch
2009 - 2014 F150
11-11-2018 12:32 PM
jpilk99
1999 to 2016 Super Duty
12-10-2017 02:16 PM
Rusty_S
25
11-08-2016 06:46 AM
olblue77
10-17-2016 04:19 PM
axelgawn
Georgia Chapter
03-05-2016 06:20 AM
Quick Reply: 99 f-450 ring and pinion change
