is it a trans cooler?
Old 01-24-2011, 07:09 PM
grizzly11's Avatar
grizzly11
grizzly11 is offline
trucks a 01 f-250 7.3psd
thanks
jared not sure trans is overheating so i was curious to were the cooler is on one of these newer trucks
Old 01-24-2011, 07:13 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
That is the power steering cooler (small one) the other is the air conditioning condenser. The trans cooler is behind that.
Old 01-24-2011, 07:14 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Or "was" a PS cooler...... lol
Old 01-24-2011, 07:32 PM
grizzly11's Avatar
grizzly11
no i didnt mess wit it just took both lines off the trans and put one end in a pail and blew it out w/ air compresser some small little black chunks came out with some creamy white w/ red trans fluid. Would running dual coolers be a good idea
Old 01-24-2011, 07:34 PM
damicofuel's Avatar
damicofuel
damicofuel is offline
Sounds like water got into the tranny. I would flush the transmission.
Old 01-24-2011, 07:47 PM
grizzly11's Avatar
grizzly11
same thing i was thinking but when i looked up all the snow was melting and there was some small pieces of ice
Old 01-24-2011, 07:54 PM
damicofuel's Avatar
damicofuel
Definitely drop pan and change filter.
Old 01-24-2011, 08:13 PM
big poppa's Avatar
big poppa
big poppa is offline
Black chunks of what?? From inside the lines or from under there near the lines??
Old 01-24-2011, 10:29 PM
Wildfire532FB's Avatar
Wildfire532FB
Wildfire532FB is offline
I have something right behind the grill that i think is the transmission cooler, i think someone moved it cause it had square bolts in it, i don't even know if its a stock one or a bigger one.
