1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
fan/heater stays on after shutting truck off?
Old 01-21-2011, 10:29 PM
'99-v10-F350's Avatar
'99-v10-F350
'99-v10-F350 is offline
Exclamation fan/heater stays on after shutting truck off?
So when i shut my truck off the heater will occasional keep blowing. it also has a string of LED type lights inside the dash by the speedometer, those also stay on sometimes. It's happened before and we thought we had it fixed. We had a whole new fuse box put in and some kind of module. Does anyone have any ideas of what could be the problem? im thinking maybe some kind of wiring? i appreciate any replies
Old 01-21-2011, 10:40 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
This is becoming more common.. The blower motor relay is what controls the motor..
When it stays on do you have all the speeds? Pull the blower relay see if it stops.
Does it go off when you put the blower switch to off..?
Old 01-21-2011, 11:15 PM
'99-v10-F350
yes all the speeds work just fine, and i've tried putting it to off but you can still hear it running. But i'm not real mechanically/electronically inclined when it comes to stuff like this, care to tell me where the relay is?
Old 01-22-2011, 06:04 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
Under the hood in the fuse relay box. Do you have a standard dash heater control etc off is up..?
Old 01-22-2011, 09:51 AM
WestCoastTodd's Avatar
WestCoastTodd
WestCoastTodd is offline
Is there any sign of water in the cab, driver's side? If the windshield is leaking, it will run down the a-pillar, and drip right on the fuse block and GEM. The blower staying on is common - happened to me. You have to take off the two big connectors on the back of the fuse block and blow them out with compressed air.
Old 01-22-2011, 04:34 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Funny thing on the 99 the gem doesn't have anything to do with the blower stuff..Now the fuse box does if it shorts...At least on my 99 CD.
Old 01-22-2011, 11:43 PM
'99-v10-F350
Well I found the fuse to it so I pulled that for tonight so it didn't die on me again (didn't pull it last night, went to go to work and what do you know batteries dead) but I'm gonna get a new relay tomorrow and I noticed a few blown fuses so I ned to replace them while I'm at it.
Old 01-23-2011, 12:13 AM
Boss_hoss's Avatar
Boss_hoss
Boss_hoss is offline
I have the same problem, I have a leak in the windshield like WestCoastTodd mentioned. When it started there was no indication of the leak because it would run along the headliner then down the pillar and shorted something out. you may want to check that out. Also in my case I just turn the heater control to off when I trurn the truck off and the blower will turn off. Its easier than pulling the fuse whenever you want the blower off.
Old 11-13-2013, 09:06 PM
rehpig's Avatar
rehpig
rehpig is offline
Trailering
I have this same problem. Did the blowing off of the fuse connectors fix the problem? I also have a problem with the daytime headlights coming on arbitrarily
Old 11-13-2013, 11:02 PM
madsonp's Avatar
madsonp
madsonp is offline
Ditto on the windshield leak, that's probably why you had to have the fuse panel and GEM replaced in the first place, take it in and have your windshield resealed, then dry out your fuse panel and GEM.
Twitchyleprechaun
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
29
01-12-2017 12:32 PM
tmathers03
1983 - 2012 Ranger & B-Series
23
11-06-2016 06:56 AM
99F350bigorange
03-31-2016 12:02 PM
bigbubba87
20
10-10-2012 06:55 PM
Vinford
11-19-2010 09:47 AM
Quick Reply: fan/heater stays on after shutting truck off?
