FYI - There is also a 3950 lb capacity spring but this is the X code with an extra tapered leaf installed on it so the 2630 is the heaviest Ford made.
ok, so then I do have X-codes, but I have X-codes with a factory add a leaf for even higher capacity? Is the 3950 per side, meaning combined load rating is 7900#?
