'49 f1 steel bed floor, what did you use?
I'm looking for patch panel for my '49 f1 steel bed floor? Need to repair my or replace it... Looking into either repair panel, flat steel, or aluminum... Don't want to use wood here in AZ, just doesn't hold up with the sun! What did you all use and how do you like it?
49Willard replaced his steel floor with a stock original, contact him for how to do it. On my 48, I'm going to switch to a wood floor. The kits you see for the later trucks don't work on ours, so I'm going to buy the wood locally and do the wood work my self. I've also seen aluminium diamond plate used, and it looks good when polished.
Hit up a few large body shops in your area and ask them if they recently did any full bed replacements. Sometimes they'll buy a used bed assembly for a few parts and will have the floor left over. Or, the damaged bed may still have a good floor.
Most of the time, they just scrap the left overs.
Jeff that looks great; that's what I plan on doing in the spring I currently have wood & SS strips after only a few months I could see the wood deteriorating; Bobby I also like the fact that you used the front panel. I may also insert my SS strips in there somewhere I hate to not use them and paid all that money for them.
The original floors are spot welded to the front panel, the bedsides and the rear U cross section crossmember. I duplicated that in my installation after replacing the original wood.
Like Ilya mentioned, talk to the local body shops, thats where I got mine. Myt buddy works at a body shop. The truck came in where the guy had dropped his 5th wheel trailer on the bed sides so they replaced the whole bed. The bed set out back andwas used to store other dented body pieces. The company they had coming around to pick up the scrap never picked up the bed so my buddy gave it to me.
Jaye, Thanks, my front panel was pretty well beat up, and since I had this one I figured I'd make it work
Fordman49F1, the original bed floors on the 48-50 trucks is a wood floor with a sheet metal cover. From what you described it sounds original. In mid year 1950 when they changed the bed style from the raised bedsides and rounded stake pockets to the flat bed sides with the square stake pockets then they also went to the traditional wooden bed floor with the metal strips.
Bobby
Bobby
