Nevada Chapter Join Chapter, Leader:67 Olfthfl
Need a front end alignment looking for a shop
Old 09-07-2010, 10:24 AM
60RatRod's Avatar
60RatRod
60RatRod is offline
So I am going to be purchasing two new front tires, before I do I want to get my front end alignment done. Anyone know of a good shop??
Thanks Dan
Old 01-07-2011, 04:50 PM
davidkstyler's Avatar
davidkstyler
davidkstyler is offline
I would like to hear of a trusted shop if you find one.
Old 01-09-2011, 10:50 PM
KC92F150's Avatar
KC92F150
KC92F150 is offline
Thanks Dan
Good luck Dan.
My son put a lift on his 93 F-150 and took it to Big O for an alignment. His tires were like this \ / when he dropped it off. I went to pick up and they were still like that. I questioned the manager and he told me they don't do the caster/camber, only the toe in/out on a front end alignment. I couldn't believe it. They wanted to charge my son $75.00 for adjusting the toe. He went and argued and got out of paying the $75. He explained to the tech how to do the alignment and then they were going to charge him $150 - $200 for the alignment. He still didin't get it aligned, I don't think he trusts them now.
I have a 97 F350 Dually, I changed a tie rod end, and Ted Weins seems to be the only place that can do a dually. I took it there and they told me that I needed both sides upper/lower ball joints, steering box and steering staberlizer before they could align it. All they wanted was 1,500.00 to fix it. That was a year ago.
Now I am not saying that either of these shops do bad work because they don't. I have had good experiences with both shops, I just didn't get any good feelings on the alignments. When I drop off my Truck for repair I like to feel confident theres not going to be and problems.
So if you find a shop you feel good with let me know so I can try to get mine aligned.
Old 01-11-2011, 12:25 PM
davidkstyler
I asked our vehicle maintenance supervisor who they use for alignments and was told:
Sears for cars, they have a computer alignment machine that is hard to screw up!
Georges (876-1299) or Arrow (873-8622) for trucks.
Hope that helps.
Old 01-16-2011, 07:38 AM
jarod17's Avatar
jarod17
jarod17 is offline
I have always been done good at Les Shwab. They have always had good rates and if there is a problem with a component they will tell you about it.
granny_rocket
03-31-2016 01:33 PM
Rocketattack
03-02-2016 11:50 AM
Davidjoe
Large Truck
01-07-2016 11:31 PM
johnmel59
02-26-2015 03:41 PM
Quick Reply: Need a front end alignment looking for a shop
