Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > South Carolina Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
South Carolina Chapter Join Chapter, Leader:
View Poll Results: Where is the IAT Sensor located on a 1992 Ford F-250 5.8L?
Too much air being delivered in engine. 0 0%
Cold start problem. 0 0%
Rich fuel smell when attempting to run cold engine. 0 0%
Fast idle during warmup. 0 0%
Voters: 0. You may not vote on this poll
  #1 (permalink)
Old 01-11-2011, 07:04 PM
PeterSr PeterSr is offline
1992 Ford F-250
PeterSr is starting off with a positive reputation.
Angry Intake Air Temperature Sensor
I recently replaced the Idle Air Control Valve on my 1992 Ford F-250 5.8L 2 wheel drive pickup truck. I thought that this move would change the way my truck was starting. Sometimes it would start just fine during warm weather, but now that it is cold, the engine sputters and races and then intermittently runs normal when starting to warm up. However, this IAC Valve didn't correct the cold starting problem. I have been advised to change out the Intake Air Temperature Sensor since this little device appears to measure amounts of cold air being taken into the engine and thus relaying the info -when it works - to the ECM. At times the intake sucks in too much air through the air intake tube and even through the Air Pump Check Valve. I need help in locating the IAT Sensor and input about correcting this problem.
Tags
1992, 58l, air, check, f150, f250, ford, iac, iat, intake, location, replacement, sensor, temp, temperature, testing, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
