Questions on a new to me '92 F150
Old 01-25-2011, 06:54 AM
92nite351's Avatar
92nite351
92nite351 is offline
good luck with that....once i go back to work in feb, i will be doing all the same things... def the tuneup
Old 01-25-2011, 09:26 AM
fordmanbrad's Avatar
fordmanbrad
fordmanbrad is offline
Hmmmmm. Ball joints, fun job!!!
Make sure that you check the front axle U joint while you have everything apart. Easy to replace when doing the ball joints. Unless it was previously replaced with one having a grease fitting, its probably shot. Even though you have lockout hubs, that joint still moves every time you turn the wheels, so they tend to wear out, especially the original ones. I took my axle to a machine shop to have the joints pressed out/in, as they are hard to do yourself without a big vise and the big C clamp like press. Come to think about it, when I did mine years ago I took both axles and both front spindles to a machine shop and got everything pressed in for like 30 dollars. Money well spent. Guy told me that it takes tons of force to do the ball joints in the spindles.
The body looks pretty good on your truck, as I see you are in snow country. How many miles are on it? All four wheel openings on mine are badly rusted.
Old 01-25-2011, 10:05 AM
Robs92's Avatar
Robs92
Robs92 is offline
Odometer says 2149xx.
Though i think there is something off. I checked with a mile marker a couple times and was reading 1.8 miles.
Old 01-25-2011, 10:16 AM
turnofftheradio's Avatar
turnofftheradio
turnofftheradio is offline
1.8 to 1 seems really far off. Search for how to program your speedo for your tires. I have not tried the procedure but it sounded easy. what size are your tires? they look approx correct. I am nervous of the tag being missing on your pillar though. look like a repaint? or an attempt to hide the vin?
Old 01-26-2011, 07:38 AM
Robs92's Avatar
Robs92
Robs92 is offline
No repaint, the tags look like they flaked off.
Old 01-29-2011, 07:32 AM
Robs92's Avatar
Robs92
Robs92 is offline
Update:
Just an update:
Had both Ball Joints replaced. Upper & Lower
Changed out both Rear Wheel Cylinders ( had to get new brakelines as they were seized up )
Changed Oil
Rear Dif. was low so changed that.
Everything looked good w/ Tranny
Found new things to address:
Timing Plate looks to have a small coolant leak... so I am watching fluid levels daily WaterPump looks OK, but its older, so will be hitting both of these at the same time, when ready.
Picking up 2 new 235/75/15 Goodyear Wrangler Radial Monday since the ones on the Rear are new. Found some for $84 ea. mounted.
Hope to have some more pics up soon.
Old 02-02-2011, 12:53 PM
Robs92's Avatar
Robs92
Robs92 is offline
went by the local muffler shope today and they checked out my exhaust for me...
looks like a stud and the donut are needing work. scheduled that for next tuesday. everything else checked out OK, found out it has a glasspack.
I think I am going to have the pipes run straight out the back.
Tomorrow scheduled for Wheel alignment.
Old 02-03-2011, 10:51 PM
Robs92's Avatar
Robs92
Robs92 is offline
Wheel alignment and new front tires today!
Old 02-04-2011, 05:44 AM
92nite351's Avatar
92nite351
dont forget we love pics on this site.....
Old 02-16-2011, 02:31 PM
Robs92's Avatar
Robs92
Robs92 is offline
Update Pics:
had to move some things so I took the shell off the back.
Old 05-25-2012, 08:48 PM
Robs92's Avatar
Robs92
Robs92 is offline
Just checking in and and still rollin the '92
just regular maintenance every 5000 miles...
Old 05-26-2012, 02:24 PM
Jacobs Daddy's Avatar
Jacobs Daddy
Jacobs Daddy is offline
Originally Posted by Lazy K
Crawl under and look for a tag on the rear axle, should have the axle info on it.
Count the number of oil pan bolts on the trans. If 17 bolts you have a C6, if 20 bolts you have an E4OD.
So which is the better to have? I have an F250 with a 351 c.i. and I tow a car trailer, 25 foot Pontoon Boat, and a 27 foot Wildwood Camper with it.
  #28
Old 05-27-2012, 07:24 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
Good question, difficult to answer.
C6 is tough as old boots but no locking toeque converter and only 3 speed with no overdrive but also no electronics (no computer needed).
E4OD has locking converter and overdrive so big improvement on fuel economy over the C6 but is electronically controlled by a computer.
You pays your money and takes your choice.
  #29
Old 05-27-2012, 07:29 AM
Jacobs Daddy
Ok, thanks for the answer. I have the E4OD in my F-250.
  #30
Old 05-28-2012, 06:41 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
The E4OD will save a fortune in gas for you over a C6 but for towing, it is essential that you keep the trans fluid cool. Maybe consider fitting an extra trans cooler if towing often.
Quick Reply: Questions on a new to me '92 F150
